25hp godevil surface drive
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=69183
Author:  duckdown [ Wed Dec 07, 2016 10:14 am ]
Post subject:  25hp godevil surface drive
I'm looking for the lightest 1648 or 1748 hull what are y'all running the same motor on a what speeds y'all get
Author:  bschwartzenburg [ Wed Dec 07, 2016 12:40 pm ]
Post subject:  Re: 25hp godevil surface drive
I'm running a 17 x 44 Southfork Mud Hull. My motor is a mudbuddy 25 hp but should be pretty close to the same results as you.
I have heads, exhaust and carb and I run 27 mph with 2 men, dog and hunting load with my big blade prop. When I put my 9" diameter prop on, I drop to 21 mph because I have to keep the rpms low enough to not hit the rev limiter.
Author:  Russ [ Wed Dec 07, 2016 12:51 pm ]
B Schwartz, get some cup and pitch added to that 9" prop. Let the engine run where it wants to and let the prop keep your rpms where they need to be.
Author:  bschwartzenburg [ Mon Dec 12, 2016 12:12 pm ]
It's currently pitched to a 14. I will look at having some more cup put into it after the season ends.
I have even thought about getting a 3 blade and having it cut down to a 9" diameter and having it worked to see if that will give me a better range of performance.
Author:  DENNYEDWARDS [ Tue Dec 13, 2016 10:10 am ]
I'm running a Alumacraft 1648 Riveted 300# hull with a Moded 45 MB BD. Turning a Hammer prop at 4500 RPM. Running lite I'm getting mid thirties, with a two man load Low thirties.
Author:  leatherwood [ Wed Jan 11, 2017 12:22 pm ]
Author:  dwbiggs [ Wed Feb 08, 2017 11:46 am ]
