Joystick steering?
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=69185
Author:  Shooter007 [ Wed Dec 07, 2016 7:36 pm ]
Post subject:  Joystick steering?
Anyone ever seen a set up with a remote steer system that has a hydrolic pump with actuator controlled by a joystick or switch rather then a steering wheel? I know this probably seems like an odd question, but I'm looking at building a new custom bowfishing rig this year and want to go with a Prodrive as my kicker. My current set up has a Kicker that has electronic throttle and steering system by powrtran. The issue I see is the power of a mud motor and weight is way to heavy for the powrtran and would need some sort of a hydrolic actuator. In theory this doesn't seem that complicated however I'd love to know if anyone has ever done it or seen it.
I don't want a steering wheel or push stick for several reason although I'm sure that would be easier. To clarify also the boat would have a normal outboad 150 plus with a surface drive just as my kicker run seperatly from the console and other motor.
Thanks
Author:  Russ [ Wed Dec 07, 2016 8:05 pm ]
Post subject:  Re: Joystick steering?
Ezyglide has a hydraulic stick. Different from typical stick steering. Pump is in the helm.
Beyond that, you're looking at finding a powerful enough electric or hydraulic motor, and rigging up a one-off system. There isn't a joystick style system that'll run a 20+ hp "kicker".
Author:  Brokeknee [ Wed Dec 07, 2016 11:17 pm ]
What set up does prodrive use on their stick steer?
Author:  SETx Longtail [ Thu Dec 08, 2016 12:52 am ]
Mechanical linkage. Not at all what this guys wanting.
Author:  uglymud [ Thu Dec 08, 2016 12:59 am ]
https://youtu.be/3NufeI5PcBk
Don't know whose it is looks like what you're thinking though.
Sent from my VS986 using Tapatalk
Author:  Darryle [ Thu Dec 08, 2016 4:06 am ]
As slow as that is to react, there has to be a better solution.
I am sure bigger rams and a higher volume pump would eliminate that. Then there is the weight of the reservoir, oil, solenoids, lines, rams and electric motor and pump.
Surplus Center would be a good start for new hydraulic parts, or find an old lift gate and salvage the all in one unit.
Author:  CypressCritter [ Thu Dec 08, 2016 9:27 am ]
SeaStar makes a auto pilot unit for their hydraulic system but it is a lot of $$$$$$$. It has a wireless remote. But I would look into a dual hydraulic helm.
Author:  Shooter007 [ Thu Dec 08, 2016 1:33 pm ]
UlgyMud, That is what I was thinking up but yes the speed is definately to slow for manuvering to try to catch up to a fish. That is kind of like what I have now but have a joystick that sits over the top of my button for left an right. I'll check out Ezy glide as well to see what they have. I really want to have all the controls in one nice cluster on a base.
Thanks for your ideas.
here's my current console for my kicker, I'd like to do somethign similar.
Author:  uglymud [ Sat Dec 10, 2016 4:05 am ]
I agree far to slow for my tastes. You could look into linear actuators like some guys are using on fan builds now
Author:  mogenduck [ Sat Dec 10, 2016 12:18 pm ]
Ive seen a couple with outboards like this but I think its what u want
https://www.youtube.com/watch?v=A0g1SmNCJ9w
Author:  Crews [ Wed Dec 14, 2016 5:28 am ]
