It is currently Fri Mar 20, 2026 5:46 am
Reply to topic  [ 9 posts ]
 Havoc 1656 DBST with 50hp Tohatsu 4 stroke
Post Havoc 1656 DBST with 50hp Tohatsu 4 stroke
Just recieved my new Havoc 1656 DBST with the .125 hull and a 50hp tohatsu. After the 2 hour break in period I was allowed to run WOT for 1 min every 10 min. Top speed was about 35-36mph by myself. Is this normal speed or a little slow since it's still in the break-in period? I know Havoc is really a speed hull but I figured I'd get low 40s with that 50hp. But so far this boat runs like a dream. Can't wait for the 3rd split of the VA season.
Thu Dec 08, 2016 5:59 pm
Post Re: Havoc 1656 DBST with 50hp Tohatsu 4 stroke
Sounds like a good speed with a 50
I gave up mud motors
Fri Dec 09, 2016 2:58 pm
I ran a similar rig with a 50 for years and never got over 35 so sounds like you're doing well
18' Weldcraft - 90HP
1654 GD 35GDSD Bone stock, including a rusty exhaust.
The only time I've rooted for the crimson tide, my gf was 3 days late.
FOREVER LSU
Sat Dec 10, 2016 6:35 pm
I'm got a friend running the same rig but not .125 and will hit 40. He has the gun box and fishing pole/sheep side tail. Or whatever you call it his also has their pods/hunt deck. I will say that I was as impressed with his as I thought I would be compared to my 1556 edge. I did not like how the nose seems to have to slight downward slant. He was running ittjis weekend hit a stump just under the water and it sunk on to the bottom luckily it was only 3-4' deep
Sun Dec 11, 2016 12:44 pm
what kind of prop you running?
Sun Dec 11, 2016 2:22 pm
I'm running a 11.1x14 aluminum prop
Wed Dec 14, 2016 1:34 am
Are you on the rev limiter with that prop when running solo?
Wed Dec 14, 2016 10:41 am
I don't have a rev meter but as far as listening to the motor and how's sounding I would say it's prolly right up there around the 6000 rpm limit
Wed Dec 14, 2016 9:56 pm
Here is a link to prop selection. Keep in mind that the aluminum will flex under load compared to stainless.
http://tohatsu.com/accessories/prop.asp
I went from aluminum 14p on a Mercury 40 to a 12p in stainless, it runs right at the limiter empty, but gained 2.5 when loaded. This is on a 1848 mud hull tho.
Thu Dec 15, 2016 7:57 am
