| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Havoc 1656 DBST with 50hp Tohatsu 4 stroke https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=69189 |
| Author: | ducktank23 [ Thu Dec 08, 2016 5:59 pm ] |
| Post subject: | Havoc 1656 DBST with 50hp Tohatsu 4 stroke |
Just recieved my new Havoc 1656 DBST with the .125 hull and a 50hp tohatsu. After the 2 hour break in period I was allowed to run WOT for 1 min every 10 min. Top speed was about 35-36mph by myself. Is this normal speed or a little slow since it's still in the break-in period? I know Havoc is really a speed hull but I figured I'd get low 40s with that 50hp. But so far this boat runs like a dream. Can't wait for the 3rd split of the VA season. |
| Author: | T-Bubba [ Fri Dec 09, 2016 2:58 pm ] |
| Post subject: | Re: Havoc 1656 DBST with 50hp Tohatsu 4 stroke |
Sounds like a good speed with a 50 |
| Author: | J_Ho [ Sat Dec 10, 2016 6:35 pm ] |
I ran a similar rig with a 50 for years and never got over 35 so sounds like you're doing well |
| Author: | dshale10 [ Sun Dec 11, 2016 12:44 pm ] |
I'm got a friend running the same rig but not .125 and will hit 40. He has the gun box and fishing pole/sheep side tail. Or whatever you call it his also has their pods/hunt deck. I will say that I was as impressed with his as I thought I would be compared to my 1556 edge. I did not like how the nose seems to have to slight downward slant. He was running ittjis weekend hit a stump just under the water and it sunk on to the bottom luckily it was only 3-4' deep |
| Author: | brightlights [ Sun Dec 11, 2016 2:22 pm ] |
what kind of prop you running? |
| Author: | ducktank23 [ Wed Dec 14, 2016 1:34 am ] |
I'm running a 11.1x14 aluminum prop |
| Author: | 50fps [ Wed Dec 14, 2016 10:41 am ] |
Are you on the rev limiter with that prop when running solo? |
| Author: | ducktank23 [ Wed Dec 14, 2016 9:56 pm ] |
I don't have a rev meter but as far as listening to the motor and how's sounding I would say it's prolly right up there around the 6000 rpm limit |
| Author: | 50fps [ Thu Dec 15, 2016 7:57 am ] |
Here is a link to prop selection. Keep in mind that the aluminum will flex under load compared to stainless. http://tohatsu.com/accessories/prop.asp I went from aluminum 14p on a Mercury 40 to a 12p in stainless, it runs right at the limiter empty, but gained 2.5 when loaded. This is on a 1848 mud hull tho. |
