It is currently Tue Mar 17, 2026 8:46 am
Reply to topic  [ 10 posts ]
 GT 1754 extreme front storage not so dry storage
Post GT 1754 extreme front storage not so dry storage
Any GTB owners having issues with the front storage leaking through the hatch and water coming under the bulkhead???? If so was it fixed by GT?
1754 GT EXTREME 37EFI
Sat Nov 05, 2016 4:05 pm
Post Re: GT 1754 extreme front storage not so dry storage
Most of these types of boats are constructed similarly, and you won't ever have complete dry storage up front. Mine will also get water up there
GTR, Waitin' on a DFOU hull
Sat Nov 05, 2016 7:51 pm
Thanks
Sun Nov 06, 2016 12:41 am
I have the same problem. Any little bit of debris will clog the drain hole up. If i keep the debris out it will stay dry unless its out in a hard rain.
Mon Nov 07, 2016 9:11 am
Same problem here... my life jackets smell terrible now because it gets wet in there.
Tue Jan 03, 2017 5:50 pm
It'll get wet...I would take my life jackets out anytime the boat got wet and hang them to dry before the next trip out to keep them from getting that stank..
35 GTR - 1754 Extreme
Wed Jan 04, 2017 9:52 am
I put weather strip around the lid on mines! Worked great
ALMOST DONT COUNT
Fri Jan 06, 2017 5:51 am
My drain tube is alays plugging up. So I now open my bow storage and put a box fan over it to circulate air and dry things out.
Fri Jan 06, 2017 7:57 am
I've got a bilge fan under my extended deck that sucks air out of the front storage. A couple small holes drilled on the other side low and high for an inlet to circulate fresh air through the box. I only run it when the humidity is less than what's in the storage area.
Fri Jan 06, 2017 10:43 am
Good idea Russ. Not sure if they make a 12v humidistat, but that would be nice to have.
Fri Jan 06, 2017 2:31 pm
