It is currently Tue Mar 17, 2026 3:54 am
Reply to topic  [ 7 posts ]
 25hp godevil surface drive
Post 25hp godevil surface drive
I'm looking for the lightest 1648 or 1748 hull what are y'all running the same motor on a what speeds y'all get
1860 center console 36 PD
Duck Down Express
[color=#FFBF00]Team Pro-Drive
Wed Dec 07, 2016 10:14 am
Post Re: 25hp godevil surface drive
I'm running a 17 x 44 Southfork Mud Hull. My motor is a mudbuddy 25 hp but should be pretty close to the same results as you.
I have heads, exhaust and carb and I run 27 mph with 2 men, dog and hunting load with my big blade prop. When I put my 9" diameter prop on, I drop to 21 mph because I have to keep the rpms low enough to not hit the rev limiter.
17 x 44 Southfork Mud Hull with a 25hp Big Block Mudbuddy
Wed Dec 07, 2016 12:40 pm
B Schwartz, get some cup and pitch added to that 9" prop. Let the engine run where it wants to and let the prop keep your rpms where they need to be.
Wed Dec 07, 2016 12:51 pm
It's currently pitched to a 14. I will look at having some more cup put into it after the season ends.
I have even thought about getting a 3 blade and having it cut down to a 9" diameter and having it worked to see if that will give me a better range of performance.
Mon Dec 12, 2016 12:12 pm
I'm running a Alumacraft 1648 Riveted 300# hull with a Moded 45 MB BD. Turning a Hammer prop at 4500 RPM. Running lite I'm getting mid thirties, with a two man load Low thirties.
Tue Dec 13, 2016 10:10 am
Wed Jan 11, 2017 12:22 pm
_________________________________
Alumacraft 1546 AW/Mudbuddy 27 Mini
Wed Feb 08, 2017 11:46 am
cron
