It is currently Tue Mar 17, 2026 4:27 pm
[ 7 posts ] |
andre_charp_
 1436 with surface drive
I'm about to purchase a 14 foot 36 inch bottom aluminum boat. Wanting to run either a 12hp or 18hp copperhead surface drive but not sure if it'll be to heavy for the boat. Anyone ever had a setup similar to this one?
| Tue Jul 05, 2016 9:13 am |
Duck2317
 Re: 1436 with surface drive
I run a 14 horse copperhead with the kohler on a 1436 riveted john boat, it does just fine. Gets me where I need to go.
| Fri Jul 08, 2016 3:49 pm |
brycecheramie
You'll be fine with either one.
| Fri Jul 08, 2016 6:39 pm |
koonce727
Joined: Sat Dec 04, 2010 7:19 pm Posts: 106 Location: Mergens Point, WI
I have a 1536 scully skiff with a 23 that does just fine
_________________ Burlap Brothers
| Sat Jul 09, 2016 1:26 pm |
Will B Free
| Sat Jul 09, 2016 2:18 pm |
markjanneck
Very new to surface drives and have a similar setup... 14HP Kohler Copperhead on an old 1436 jon w/ 16" transom. For the life of me I cannot get this thing to run the speeds yall are getting. I try to change the trim and that does not seem to help. Maybe it is a balance/loading issue. ANY help is appreciated on how yall load this set up. I roughly weigh 180lbs.
| Sun Apr 30, 2017 8:19 pm |
bigticket
Joined: Thu Jan 09, 2014 11:40 pm Posts: 94 Location: somewhere fishing
Put some weight in the nose of boat , a battery/gas tank, if its too light it may never plane too much rear weight and it will just plow. Had a simular problem on a 1436 until i got it loaded right.
Sent from my SAMSUNG-SM-G935A using Tapatalk
_________________ 1654 GDSD 37efi.
| Fri May 05, 2017 7:14 pm |
[ 7 posts ] |
