It is currently Tue Mar 17, 2026 12:53 pm
Reply to topic  [ 15 posts ]
 Academy McClain trailer modifications
Post Academy McClain trailer modifications
I didn't know if this is the correct forum for this or not, my apologies if not.
I am trying to decide what to do exactly to modify the trailer I bought to fit the "Runt" (Atchafalaya Outdoor Designs version of the Midget) and carry it safely.
Trailer as is specifications:
Length: 16 1/2'
DBF: 42"
The Runt is
12' 3" long overall
44" wide at the chine
56" beam
My current plans are to order a complete square galvanized 60" axle kit, build a new upper frame that is either 6' or 8' long and 48" wide using 11ga 2" x 2" for cross members and 11ga 2" x 3" for the outer rails. The tubing would be flush on the bottom and that would allow me to butt the bunks up against the outer rail and space them evenly from the edge and under the runners. For bunks I was thinking 2x6 on the outside and 2x4s under the runners. The bunks will screw directly to the cross members and have Gator Glide on them.
There will also be some form of guides on the rear as well, haven't decided on the style I want yet.
I am going weld 3" x 2" angle iron feet on both sides the cross members and use u-bolts to attach the upper frame to the tongue of the trailer.
I am planning on using 13" wheels and the 2" x 3" tubing allows me to move the original fenders up for clearance.
I am using the original axle, springs, tires, wheels and upper frame to build a kayak trailer.
I will also have the new upper frame hot galvanized dipped by a local company.
Here is a crude drawing of what I was thinking
Here is a stock photo of the trailer as it comes from McClain:
Pictures of the Runt:
This will be hanging off the back:
2017 Atchafalaya Outdoor Designs 1244
2017 Copperhead 12hp
Tue Feb 21, 2017 9:41 am
Post Re: Academy McClain trailer modifications
I feel like, for the money you will have spent on the trailer and modding it, you could just have bought the right trailer for it...
or even a good used trailer.
Tue Feb 21, 2017 9:47 am
There is no such animal here, I have been looking for a couple of months, everything was junk and the only trailer I found in stock was $1700 and the dealer said he was making me a deal and I was going to have to modify it to work.
The boat is light, 2 people can pick it up easily and the motor is 120lbs, just awkward to handle.
Tue Feb 21, 2017 11:23 am
http://www.louisianasportsman.com/lpca/ ... subcat=648
Tue Feb 21, 2017 11:28 am
Tue Feb 21, 2017 1:49 pm
haha, totally understand.
I could have sworn you can get a trailer from a seller In the $1200 range
I could be wrong though.
Tue Feb 21, 2017 1:51 pm
Check with bass pro shops to see if you can get a tracker trailer that they sell for their aluminum boats.
WC Custom 1854
Tue Feb 21, 2017 2:57 pm
What engine block is that?
Tue Feb 21, 2017 2:59 pm
That is the 12hp LCT Copperhead
Tue Feb 21, 2017 8:37 pm
Tue Feb 21, 2017 10:18 pm
That's the Lake Lewisville syndrome :lol:
-Custom pool noodle
-stage 4 water wings
Tue Feb 21, 2017 10:23 pm
Tue Feb 21, 2017 10:30 pm
People spending money they don't have to impress people they don't know. It's an odd phenomena.
-Custom pool noodle
Tue Feb 21, 2017 10:31 pm
A buddy of mine uses the same trailer to carry a 15x48 Weldbuilt 100 ga. with a Yamaha 25 hp 4 stoke. the only thing he added was guides to help center the boat when loading. Works good for him and pulls good too!
Wed Feb 22, 2017 10:32 am
Frame is just about complete. I am waiting on the steel housings for the oval tail lights and then I will put it together. I am having it hot dipped galvanized. It is ยข42 a pound, I don't even make the minimum charge weight of 371lbs, so it will cost me $100 with a 5 day turn around. I carried the frame in the garage on my shoulder, calculated it weighs about 145lbs.
Sun Feb 26, 2017 8:02 pm
