It is currently Fri Mar 20, 2026 5:46 am
Reply to topic  [ 14 posts ]
 made a big mod to the rig
Post made a big mod to the rig
My boat was taking a beating on some rocks in the river I run so I had to figure out a way to increase the hull protection. I did a bunch of research and figured id trust in how the guys with jet boats protect their hull since they primarily run shallow rocky rivers.
I added a 3/16" polyurea topcoat for impact resistance. It was sprayed on smooth. I also ordered Gator Glide to put on over the poly so the rocks don't "bite" it and gives added slickness. The added weight (approx. 120lbs of material) should be negated by the slickness when it comes to speed of the boat and now I have a much more impact resistant hull! Only time will tell if this holds up or not. Fingers crossed that I didn't waste a bunch of money on this.
Mon Feb 20, 2017 11:39 am
Post Re: made a big mod to the rig
How much was that
Mon Feb 20, 2017 11:41 am
Looks like that hull was already hooked all to shit.
Mon Feb 20, 2017 12:00 pm
You have just sent whatever you spent to me.... probably did about as much good lol...
Seriously though, I'm sure that's not a cheap process. I would have put it towards a hull built for what you're doing. That things seen better days for sure.
Mon Feb 20, 2017 12:13 pm
I didn't think gator glide stuck to polly?
Mon Feb 20, 2017 12:28 pm
I don't travel far over water to hunt so I don't need to go fast. This was a wayyyy cheaper alternative to buying a new hull. The river is treacherous and would likely F up a new hull anyways.
Frog said it will stick to the coating.
Mon Feb 20, 2017 12:53 pm
Curious to see how it holds up. Good luck I hope it works for you.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Feb 20, 2017 1:15 pm
GG went on nicely. got 4 coats on the bottom with 1/2 gal. Stuff is slicker than a virgin's pvss on her wedding night. love it.
Mon Mar 06, 2017 12:07 pm
I would have at least beat the hooks back out before I did all that :?
Tue Mar 07, 2017 3:14 pm
no access to the underside of the floor
Tue Mar 07, 2017 4:03 pm
You gotten this thing in the water yet? curious how it changed your ride
Thu Apr 06, 2017 9:26 am
not yet, I'm hoping to get out next week. Headed to FL this weekend on a tarpon fishing trip.
Thu Apr 06, 2017 9:39 am
How did it work?
Sun May 07, 2017 11:17 pm
impact resistance improved substantially. took it over the same water that was giving me trouble with no issue. However the GG didn't adhere to the liner as expected. I spoke with frog and we are working on a solution. I basically have to run my current application off and then re-apply with a few more prep steps. overall pleased with the direction its going and will be happy when its complete.
Mon May 08, 2017 1:21 pm
