| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| New beginnings https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=70069 |
Page 1 of 4 |
| Author: | MNwingsetter [ Thu Mar 16, 2017 4:48 pm ] |
| Post subject: | New beginnings |
So marks the first stage of my new boat build! 1942 with 24 inch sides... all .125IMG_1087.JPG Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Thu Mar 16, 2017 6:00 pm ] |
| Post subject: | Re: New beginnings |
IMG_1091.JPG Sent from my iPhone using Tapatalk |
| Author: | mikebyers [ Thu Mar 16, 2017 8:48 pm ] |
What town are you in? I was considering building a new hull myself. might be nice to compare notes. |
| Author: | MNwingsetter [ Thu Mar 16, 2017 8:57 pm ] |
I live south of the twin cities... Sent from my iPhone using Tapatalk |
| Author: | 4Cody4 [ Thu Mar 16, 2017 9:11 pm ] |
Who is building your boat? Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Fri Mar 17, 2017 3:51 am ] |
| Author: | CypressCritter [ Fri Mar 17, 2017 8:03 am ] |
I thought my old 18x46 was a canoe, that's narrow. 24" sides, tall and skinny. Ought to get pretty good speeds with a 35/37 hp. What motor you going with? |
| Author: | MNwingsetter [ Fri Mar 17, 2017 8:19 am ] |
| Author: | cb5331 [ Fri Mar 17, 2017 8:21 am ] |
Looks like a bathtub. |
| Author: | MNwingsetter [ Fri Mar 17, 2017 8:44 am ] |
| Author: | flint87 [ Fri Mar 17, 2017 4:48 pm ] |
| Author: | MNwingsetter [ Fri Mar 17, 2017 6:19 pm ] |
Seems like the longer, narrower hulls perform better with LTs... I figure it would be a fast rig with a surface drive, and as far as load carrying goes, I don't have that many friends........ Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Fri Mar 17, 2017 6:49 pm ] |
Or I mean longtails perform better on longer narrower hulls* Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Fri Mar 17, 2017 7:59 pm ] |
IMG_1097.JPG Sent from my iPhone using Tapatalk |
| Author: | mikebyers [ Sat Mar 18, 2017 8:35 am ] |
Who did you use as your material supplier, and did you consider having a 1 piece hull bent? |
| Author: | MNwingsetter [ Sat Mar 18, 2017 8:42 am ] |
| Author: | mikebyers [ Sat Mar 18, 2017 8:59 am ] |
I use discount steel for most of my materials. I was looking at their website last night and it looks like they have a 18' brake. I saw that Gale marine in Galesville Wi. (near Lacrosse) does boat fab work, and has a 20' brake. not sure if they can easily get 10' x 20' materials at a reasonable cost. Love what you've got started. I think that the tall sides make the bottom look narrower than it actually is. I bet it looks different in person compared to the pictures. Keep the pics comin. |
| Author: | mikebyers [ Sat Mar 18, 2017 9:04 am ] |
Also, does the bottom taper in width from front to back or does it just appear to in the pictures? |
| Author: | MNwingsetter [ Sat Mar 18, 2017 9:12 am ] |
| Author: | MNwingsetter [ Sat Mar 18, 2017 9:14 am ] |
| Author: | Darryle [ Sat Mar 18, 2017 10:08 am ] |
| Author: | MNwingsetter [ Sat Mar 18, 2017 10:18 am ] |
| Author: | mikebyers [ Sat Mar 18, 2017 12:21 pm ] |
with the 24" sides, will there be a clearance issue with the front of the motor (when trimmed up) and the back bar of the cockpit with having a hunt deck? I assume you will be putting a tall transom motor on it. |
| Author: | MNwingsetter [ Sat Mar 18, 2017 1:09 pm ] |
No... and since my motor has a tilting tiller even if that fucker comes flying out of the water and the tiller were to strike the false transom, that pivot would protect anything from harm Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Sat Mar 18, 2017 1:10 pm ] |
That being said I might make a transition to a lower height for the false transom for getting in and out easier... but that could always come later Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Sat Mar 18, 2017 1:12 pm ] |
1.5" round tube that I ripped in half for the gunnel trim/ rub rail... also getting catwalks but that's a few days of work away IMG_1100.JPG Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Sat Mar 18, 2017 5:05 pm ] |
Got the gunnel trim tacked on... and the sides fully welded to the bottom on the inside... now for the rest of the floor braces IMG_1102.JPG Sent from my iPhone using Tapatalk |
| Author: | mikebyers [ Sat Mar 18, 2017 7:38 pm ] |
Is your rub rail and bottom bracing 6061? did you bend the rake into your floor bracing your self, and how? |
| Author: | MNwingsetter [ Sat Mar 18, 2017 7:47 pm ] |
| Author: | mikebyers [ Fri Mar 24, 2017 3:18 pm ] |
Well Discount steel said their maximum length for a break is 12' and Gale marine said they can make a bend up to 20', but cant bend a one piece hull because the maximum between centers on their machine is also 12'. How is your build coming? you havent posted any new pics for a while. |
| Author: | MNwingsetter [ Fri Mar 24, 2017 5:42 pm ] |
| Author: | MNwingsetter [ Fri Mar 24, 2017 6:02 pm ] |
That and my motor won't be built till like halfway through April, so I'm not necessarily in any hurry. Spose I could get it done and paint it though. Sent from my iPhone using Tapatalk |
| Author: | mikebyers [ Fri Mar 24, 2017 6:35 pm ] |
| Author: | MNwingsetter [ Fri Mar 24, 2017 6:41 pm ] |
Haha I hear ya, buddy of mine just nabbed a gtr from a guy in Louisiana, and I'm about to make the same trek once my XD is done... not thrilled, but also nice to get out of town for a few days Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Sun Apr 09, 2017 6:08 pm ] |
IMG_1189.JPG Finally working on the boat again... got my floor braces all welded in this afternoon... now things should really begin to roll Sent from my iPhone using Tapatalk |
| Author: | mikebyers [ Sun Apr 09, 2017 8:05 pm ] |
looks a little weak, I think you should have tried to fit 2 more braces in it. Haha |
| Author: | MNwingsetter [ Sun Apr 09, 2017 9:10 pm ] |
| Author: | Smoke [ Mon Apr 10, 2017 4:36 am ] |
| Author: | MNwingsetter [ Mon Apr 10, 2017 5:59 pm ] |
IMG_1194.JPG Cross braces installed Sent from my iPhone using Tapatalk |
| Author: | MNwingsetter [ Tue Apr 11, 2017 3:52 pm ] |
IMG_1197.JPG First front deck brace and catwalk framed Sent from my iPhone using Tapatalk |
| Page 1 of 4 | All times are UTC - 6 hours |
