https://mudmotortalk.com/mmt_v2/
water wings or spray rail on go devil hull
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=70141
Author:  tystorm [ Mon Mar 27, 2017 5:21 pm ]
Post subject:  water wings or spray rail on go devil hull
i just got my first mud hull, a 1644 go devil. it is the older round chine hull. i have my 35 gdsd on it and tested it today and did fairly well. only complaint i have is the water come up to the top of the gunnel on plane due to the thrust of the motor. ive seen a few pictures of hulls with a rail welded down the side but would like to see more detailed pics of this or something similar if anyone has them. also read that wedges may help. open to any thoughts or suggestions. just looking to see pictures of what others have found to work. thanks
Author:  Will C [ Tue Mar 28, 2017 10:47 am ]
Post subject:  Re: water wings or spray rail on go devil hull
That boat is borderline big enough. Any chance you have waterlogged foam weighing it down? Saving Flint the trouble.. what does the bottom look like?
Author:  tystorm [ Tue Mar 28, 2017 2:19 pm ]
Ive checked the foam. Had a little bit wet in the front but I cut that out and the rest is dry. The floor foam was previously removed. The bottom is in fair shape. One dent towards the back and a slight wave but nothing else significant
Author:  flint87 [ Tue Mar 28, 2017 2:35 pm ]
I had an 1844 that did the same and the foam was out of it. Wall of green water above the rail... always hated looking at that.
Author:  tystorm [ Tue Mar 28, 2017 2:39 pm ]
Yea I've read about small 1/2 inch wedges on the bottom helping to give it more lift and was thing that in combination with a spray rail may help
Author:  caddobrook [ Tue Mar 28, 2017 3:27 pm ]
Some will certainly disagree, but IMO that is just not enough boat for that motor.
That boat is for a long tail.
You have a combination of short and narrow. Then add the round chine. Not good for a SD.
I would spend very little time and money chasing it, and focus on saving the money to upgrade the boat.
That is a good boat and I would imagine you could get some decent money for it, put a little with that and then get you a better boat for your motor. You need longer and wider, but at least one of those.....
Author:  Will C [ Tue Mar 28, 2017 4:18 pm ]
Well said^^
Author:  tystorm [ Tue Mar 28, 2017 4:43 pm ]
I understand he above, but for my purposes a wider or longer boat would make it very difficult to use. We launch anywhere from open ramps to Tiny roadside ditches. I really like the size and it works as it is for me just thought if a small adjustment would help improve then it may be worth it
Author:  SETx Longtail [ Tue Mar 28, 2017 6:53 pm ]
I'd be willing to bet an 1844 will go 99% of where that 1644 will and perform all around much better with a SD
Author:  tystorm [ Tue Mar 28, 2017 7:30 pm ]
The Ditches I run my 14ft was tight. The 16 is about all one person can run solo. We had a 18 through them but some one has to stand up front and push the bow around. So yea an 18 would be doable but I'd rather make the shorter hull work
Author:  cb5331 [ Tue Mar 28, 2017 10:00 pm ]
You could always put pods on it. :?
Author:  MNwingsetter [ Wed Mar 29, 2017 6:29 am ]
Author:  tystorm [ Wed Mar 29, 2017 3:26 pm ]
I used epoxy and put on some wedges to see what happens. Worst case I'll pull them off
Author:  pokey79 [ Thu Mar 30, 2017 8:40 am ]
he did say it has a hook on the bottom in the back , so that will kill your performance!
Author:  flint87 [ Thu Mar 30, 2017 9:25 am ]
Author:  tystorm [ Thu Mar 30, 2017 11:32 am ]
i put them on yesterday using jb weld to see if they would work. made two wedges 4 inches each. left the one side two inches and cut the other to about a third of an inch. tested it today solo and the back jumped right up and i had about 8-9 inches of freeboard where before i had water almost right to the gunnel. only had deep water to test in. did lose 1-2mph. i think i need to shave them down a little because the bow was almost plowing and i think thats part of the speed loss. but for what its worth i think they should help and make this combo work well
Author:  Will C [ Thu Mar 30, 2017 1:14 pm ]
Its fun testing water toys. How bout a pic?
Author:  cb5331 [ Thu Mar 30, 2017 1:38 pm ]
My floating chairs and floating cooler are the best water toys there is. :lol:
Author:  Will C [ Thu Mar 30, 2017 2:09 pm ]
As long as the kawi gets u there... :D
Author:  cb5331 [ Thu Mar 30, 2017 2:17 pm ]
It will get there. Might be a day late, but it'll get there. :lol:
Author:  tystorm [ Thu Mar 30, 2017 3:24 pm ]
Here's pics of it. Still lots of stuff I wanna do but at least it's up and running
Author:  flint87 [ Thu Mar 30, 2017 4:50 pm ]
GRASSHOPPER
Author:  tystorm [ Thu Mar 30, 2017 5:40 pm ]
i drove to SC from MD to pick it up. on both sides the g and r someone tried to scrape off haha
Author:  Will C [ Thu Mar 30, 2017 10:49 pm ]
Nice lil boat. Custom pipe too. I meant a pic of the wedges :D
Author:  flint87 [ Fri Mar 31, 2017 6:01 am ]
Author:  tystorm [ Sat Apr 01, 2017 12:21 pm ]
They are just on with epoxy for now so. It the prettiest but you get the idea
Author:  Will C [ Sat Apr 01, 2017 1:24 pm ]
Pretty cool that those little guys change so much
Author:  tystorm [ Sat Apr 01, 2017 5:40 pm ]
Yea I had very little faith when I was putting them on it it was amazing to me the difference in the ride
Author:  kirk [ Sun Apr 02, 2017 5:30 pm ]
are you gonna adjust the size of them anymore? Or maybe have something permanently welded on once you figure out what works best?
Author:  tystorm [ Sun Apr 02, 2017 7:02 pm ]
im going to grind them down a little and see if it will bring the bow back up a little. i ran it for a while today solo and it did great im just worried if i get a load in it the front will plow too much. but as long as i find the sweet spot i may have them welded on im not sure. the jb weld holding them on didnt break today and we ran a fair amount of mud and hit a few stumps/logs. solo today it ran 28 with just me and a small cooler. was running right with my buddies excel and modded mud buddy
