It is currently Tue Mar 17, 2026 6:07 pm
Reply to topic  [ 7 posts ]
 1436 with surface drive
Post 1436 with surface drive
I'm about to purchase a 14 foot 36 inch bottom aluminum boat. Wanting to run either a 12hp or 18hp copperhead surface drive but not sure if it'll be to heavy for the boat. Anyone ever had a setup similar to this one?
Tue Jul 05, 2016 9:13 am
Post Re: 1436 with surface drive
I run a 14 horse copperhead with the kohler on a 1436 riveted john boat, it does just fine. Gets me where I need to go.
Fri Jul 08, 2016 3:49 pm
You'll be fine with either one.
Fri Jul 08, 2016 6:39 pm
I have a 1536 scully skiff with a 23 that does just fine
Burlap Brothers
Sat Jul 09, 2016 1:26 pm
Sat Jul 09, 2016 2:18 pm
Very new to surface drives and have a similar setup... 14HP Kohler Copperhead on an old 1436 jon w/ 16" transom. For the life of me I cannot get this thing to run the speeds yall are getting. I try to change the trim and that does not seem to help. Maybe it is a balance/loading issue. ANY help is appreciated on how yall load this set up. I roughly weigh 180lbs.
Sun Apr 30, 2017 8:19 pm
Put some weight in the nose of boat , a battery/gas tank, if its too light it may never plane too much rear weight and it will just plow. Had a simular problem on a 1436 until i got it loaded right.
Sent from my SAMSUNG-SM-G935A using Tapatalk
1654 GDSD 37efi.
Fri May 05, 2017 7:14 pm
