It is currently Tue Mar 17, 2026 4:05 am
Reply to topic  [ 20 posts ]
 Drain plug size
Post Drain plug size
Ok I have 1 3/8 drain holes. What plugs are you guys useing ? Thanks
Fri May 26, 2017 8:29 am
Post Re: Drain plug size
um, a plug that fits in the hole and doesn't leak maybe???
Refurbishing a Prodrive
Fri May 26, 2017 8:35 am
Go to Amazon and search: Turn-Tite Expandable Neoprene Rubber
This
F-this:
1244 Atchafalaya Outdoor Designs W/ 12hp Copperhead
2017 Atchafalaya Outdoor Designs 1244
2017 Copperhead 12hp
Fri May 26, 2017 10:11 am
Plumber's plug from your local hardware store. Buy a spare or two.
Fri May 26, 2017 8:07 pm
Sat May 27, 2017 5:10 am
That's the one. Try a plumbing supply store.
Sat May 27, 2017 7:42 am
Sat May 27, 2017 10:14 am
I've used an expandable rubber freeze plug before. They seal great. But you need a crescent wrench or something to install/remove them.
Sat May 27, 2017 10:22 am
Thanks guys I'll have to see what I can find
Sun May 28, 2017 6:35 am
Wal-Mart
GATORTRAX 1754, HUNT DECK, GTR35 STAGE 3
Sun May 28, 2017 9:10 pm
Are these interior or exterior if exterior use screw in plugs I don't trust those flip plugs to not get caught on something and flip open
Mon May 29, 2017 1:14 am
I installed mine on the inside and me and another guy never could get the flip one to flip once it was adjusted to size, it was impossible even though it was a snug fit to begin with.
I use the T-handle one easily and it stays put and is nearly flush on the outside.
Mon May 29, 2017 5:30 am
Plug it in from inside the hull....you don't want that big plug getting pulled out accidentally by getting tangled up in anything you're riding through.
Mon May 29, 2017 11:41 am
I have one standard size marine plug in the transom and one 2" hole in the transom for hosing out the crap that accumulates.
Fri Jun 02, 2017 2:39 pm
Fri Jun 02, 2017 6:17 pm
Fri Jun 02, 2017 6:41 pm
Hopefully he chimes in here
Fri Jun 02, 2017 9:12 pm
My 2" plug is a expamdable frost plug that I got from an auto parts store. Works fantastic. I'll take a picture and post it tomorrow.
I'll never have another boat without a 2" plug.
Fri Jun 02, 2017 9:58 pm
It's like this only 2", not 3 like the picture shows.
http://www.mrsupply.com/cherne-econ-o-g ... AtlG8P8HAQ
Fri Jun 02, 2017 10:01 pm
That's gotta make washing the trash out way easier. Next boat will have it.
Fri Jun 02, 2017 10:19 pm
