It is currently Mon Mar 16, 2026 6:01 pm
Reply to topic  [ 11 posts ]
 14X48 Alweld jon boat and a 23 gdsd
Post 14X48 Alweld jon boat and a 23 gdsd
New to mud motors and looking for input on this boat and motor configuration. Best starting point for battery and fuel tank placement given I'm around 280 lbs myself. Any good advice is appreciated as I set up the boat
Sat Jun 03, 2017 8:41 am
Post Re: 14X52 Alweld jon boat and a 23 gdsd
Well with my fat biscuit in the back with the group 24 battery and 6 gallon tank. I learned all but me needs to get out the back and try again once the rain clears out. Wow totally different beast to run then a regular ole tiller outboard.
Sat Jun 03, 2017 9:32 pm
When I had a 16x38 with a 25 hp LT, I had to put the fuel up in the front.
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Sat Jun 03, 2017 9:57 pm
There's a chance you may even want to throw some extra weight up front to balance the load. Maybe make up a tool kit/box that you can put in front too.
Sun Jun 04, 2017 4:21 am
Going to make battery cables and hunt for fuel line today so I can move everything up front. So roughly move 75-80 lbs off the back plus still yet to put the 60 lb accessorie/trolling battery in up front. Not planning on doing a lot of muddling just mainly running the amite river from Denham Springs and Darlington.
Sun Jun 04, 2017 7:25 am
Post Re: 14X48 Alweld jon boat and a 23 gdsd
slight topic change as i was going off the previous owners description of a 14X52 when its truly a 14X48...On that note what is the thoughts on adding a 18" hunt deck to the rear of the boat?
Wed Jun 07, 2017 7:03 pm
I wouldn't...
Refurbishing a Prodrive
Wed Jun 07, 2017 7:17 pm
You need a 18x46, i just happen to have one available! :shock:
Wed Jun 07, 2017 9:00 pm
I' m going to run it like it is for a bit or maybe put the 23 gdsd on the 16X48 bateau i have till i get or make the hull i need for running in the area i intend on using it most
Thu Jun 08, 2017 9:33 pm
What you got at mcdonalds
Fri Jun 09, 2017 2:11 am
Fri Jun 09, 2017 2:27 am
