It is currently Mon Mar 16, 2026 11:02 pm
Reply to topic  [ 10 posts ]
 Go devil boat shallow water anchor mounts
Post Go devil boat shallow water anchor mounts
Guys i need a few ideas or pics for
spud pole mount for the bow of my gd 1654 boat i was going to just weld a id 1- 1/2 sched 40 tube to the front and to that rib that runs vertical on the nose of the boat but im just not sure.
Has anyone on here done that? Brand new boat trying not to screw too much with it. - Thanks
Sent from my SAMSUNG-SM-G935A using Tapatalk
1654 GDSD 37efi.
Thu Jun 22, 2017 6:42 pm
Post Re: Go devil boat shallow water anchor mounts
You can buy the brackets from GD that mount on the boat using riv-nuts. The local dealer here in Beaumont had some on a boat he was working on. They aren't on GD website, you might have to call them
Thu Jun 22, 2017 8:25 pm
Ok thanks i didnt even know they had them that may work a lot better.
::Edited::
Googled a pic is this what you was talking about?
1654 GDSD 37efi.
Thu Jun 22, 2017 8:28 pm
Or weld that tube slot to a c-clamp, add hydro turf to the jaw of the clamp. Clamp anywhere you want it at . Portable , move able , spud pole bracket. I've a go devil boat and that's what I did .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Thu Jun 22, 2017 8:55 pm
I have what's pictured there on that boat, except mines welded on. GoDevil is doing spud holes thru the front deck nowadays. I've thought many times about cutting mine off and finding a builder to put one through the deck of mine. It's just cleaner and out of the way. I have smacked mine on a dock once or twice and egg shaped it, you can't really just drop a pole thru it anymore. It hangs up. If you do that external bracket just make sure it's somewhere out of the way where it won't get hit head on by something real solid. It'll basically render it useless.
-Custom pool noodle
-stage 4 water wings
Thu Jun 22, 2017 10:12 pm
Thanks guys thats what im worried about because i run a lot of flooded timber here in ark. Its gonna get smacked around a lil.
But really needing it for places like red river and sulpher river where there are no places to tie up.
Good idea -huck.
1654 GDSD 37efi.
Thu Jun 22, 2017 11:00 pm
Yes that's what I as talking about. Mine new boat is thru the hull, but the last GD I had I bought used and the guy had added thru hull by a welder
Thu Jun 22, 2017 11:41 pm
You could get a stiffy and just attach it with a leash...
"There's nothing a duck hunter hates more than another duck hunter."
Fri Jun 23, 2017 6:42 am
Back in the younger redneck days, pvc poles with end caps and a "T" in one end and spray can foam filled, stuck them in the mud and tied the boat to them. Worked well even when a tug and tow came down the Intercoastal and did that "suck the water out then tidal waved back in".
Fri Jun 23, 2017 7:39 am
Fri Jun 23, 2017 3:44 pm
