It is currently Mon Mar 16, 2026 9:28 pm
[ 6 posts ] |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Porpoise fix
Is there an advantage to using wedges vs just running a weld bead to fix the issue? I'm gonna have to do one of the other. My bow is riding just a bit higher than I'd like and it tries to porpoise at around 3600-3700. Tank is in the front.
_________________ 1850 & 36pd
| Sat Aug 12, 2017 4:39 pm |
brycecheramie
 Re: Porpoise fix
I had good results with a bead across the bottom at the transom on other boats. I've also gotten lucky and do not porpoise at all on my current boat. this boat does not have anything under it helping.
My boat is only a 16x44 and it likes all the weight in the back.
| Sat Aug 12, 2017 4:45 pm |
med
 Re: Porpoise fix
This an 1850. But the way I built my transom the motor is actually mounted about a 1/2" high. That may be the reason for my issue. Not sure.
| Sat Aug 12, 2017 4:59 pm |
brycecheramie
 Re: Porpoise fix
Seems like that would make it not hop. But, these things are finicky. I'm no expert on transom matching....
| Sat Aug 12, 2017 5:06 pm |
Russ
 Re: Porpoise fix
Shift more weight to the rear when you're running. Porpoising is actually not caused by too much weight in the rear and needing a wedge to drop the bow. It happens when your boat pitches forward because of the lift at the rear, then the boat slows because of the loss in lift and increase in friction, making it drop at the rear again, lather rinse repeat. Dropping the bow while running using the wedge/weld can help, but having more weight to the rear to keep the stern as your main point of lift is countering the actual issue that's occurring. Getting the rake adjusted in your prop can drop the bow as well. Ultimately, the balance point front to rear of your boat is in the wrong spot. Putting more weight up front can have the same end result, but is shifting the balance point forward. Youll have better (may not be very noticeable or may be night and day) performance with the weight added rear as your hull will be at a better angle to create lift, instead of the water passing under easier. Ill admit im splitting hairs (the difference isnt huge) but run shallow water, hard bottom, and 10 feet can mean planing out or dragging a boat lol
That being said, every one of these setups are different, and you may benefit from the weight forward more than i did. Im also going to add 2 8" beads at the rear of mine, but for a different reason.
| Sat Aug 12, 2017 5:18 pm |
Will C
 Re: Porpoise fix
My boat has the small go devil style notchback on it. I welded in 1 1/2 inch of trim tab to it. Works great. Just a little tweak up or down really shows how it rides and solved my bounce
| Sun Aug 13, 2017 10:42 am |
[ 6 posts ] |
