It is currently Mon Mar 16, 2026 11:55 am
Reply to topic  [ 14 posts ]
 bowfishing decks
Post bowfishing decks
how do you guys have your bowfishing decks rigged up removable so you can use your boats all year long?
Thu May 18, 2017 10:09 am
Post Re: bowfishing decks
Eyelet and turnbuckles
Thread inserts and thumbscrews
Thu May 18, 2017 10:13 am
See link above. We can build them for any boat, and with all sorts of options like rails, lights, seats, steps, etc.
Thu May 18, 2017 10:17 am
My deck sits over top of my catwalks and bolts in place. Then my light rail is detachable as well. I don't run a raised deck on my boat, I don't care for them.
Thu May 18, 2017 12:18 pm
^ love it. I have seen some of those drop in platform extensions. its a great way to save weight. few ?'s:
How do your rails mount?
what kind of lights you run?
it looks like there is a break in your rail for a trolling motor, do you have 2 wires coming back to the generator or did you figure a way to run it with only 1?
Thu May 18, 2017 2:42 pm
My rails have feet on them and I just bolt them on into riv-nuts that are in my boat. I'll take some photos later.
I run a mix of 27 and 48 watt led lights you can buy on Amazon now. I have all of mine tinted yellow and it helps a lot.
Thu May 18, 2017 2:54 pm
you ever grab pics?
Thu Aug 24, 2017 1:22 pm
Shoot, no I never did.
I'll try and grab some pics tonight.
Thu Aug 24, 2017 3:20 pm
This is my deck extension. It rests on my catwalks and seems plenty sturdy. It drops in and bolts in place with 4 rivnuts , I've never had any issues with that either.
Thu Aug 24, 2017 8:06 pm
Here is my light bar. It also bolts in place with rivnuts. I use a bolt on each foot and it's super sturdy. I had the stock Garortail rail split and added the flat part where I mount my troller. Im running a mix of 27 and 48 watt LED lights tinted yellow and run them off 2 batteries (12v).
Thu Aug 24, 2017 8:09 pm
The lights plug into one side where I ran the wire to the back of the boat under the catwalk. The troller plugs into the other side and that cable also runs to the back.
Thu Aug 24, 2017 8:10 pm
Sorry I didn't throw the lights on the boat. Let me know if you want pics of anything else.
Thu Aug 24, 2017 8:11 pm
Dude that is slick! Love it. Thanks for posting
Fri Aug 25, 2017 10:03 am
Modifying the light bar was the biggest change. Being able to use the trolling motor regularly and keeping the light rail on was huge.
Fri Aug 25, 2017 10:31 am
