| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Led navigation light https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=71407 |
| Author: | Brokeknee [ Thu Oct 12, 2017 8:30 pm ] |
| Post subject: | Led navigation light |
I'm tired of my rear navigation light getting torn off, and I'm thinking about mounting an led strip on the rear of the motor. I've seen this done once or twice but I'm curious if it is legal? I plan on doing a few out of state hunts this year and don't want a game warden harassing me for something little. |
| Author: | brycecheramie [ Thu Oct 12, 2017 8:33 pm ] |
| Post subject: | Re: Led navigation light |
| Author: | 4Cody4 [ Thu Oct 12, 2017 9:17 pm ] |
Max It Out LED stern light Sent from my iPhone using Tapatalk |
| Author: | brycecheramie [ Thu Oct 12, 2017 9:27 pm ] |
| Author: | Russ [ Thu Oct 12, 2017 9:30 pm ] |
https://www.amazon.com/Marine-Yacht-Nav ... ion+lights something like this on top of your motor. they make some that aren't quite so tall, but it's only 3". #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Koondog62 [ Fri Oct 13, 2017 2:41 am ] |
The stern/anchor light must be visible for 360 degrees. So if the light on the motor does that then you should not have any issues. Just FYI your port/starboard bow lights are 112 degree lights. |
| Author: | Brokeknee [ Fri Oct 13, 2017 3:36 am ] |
| Author: | Smoke [ Fri Oct 13, 2017 4:39 am ] |
Spend the money on a max it out light and never look back. These things are indestructible and mounted with a ram mount. Any light mounted rigid I promise you I will break it off somehow. I went through those light weight aluminum ones every year it seemed. I've had the max it out for 4 years and its going strong and I have hit branches with it at 30 mph and it just flops out of the way. |
| Author: | cb5331 [ Fri Oct 13, 2017 1:54 pm ] |
I use one of these. https://www.hodgesmarine.com/Attwood-Le ... iramsegdoh |
| Author: | Russ [ Fri Oct 13, 2017 2:48 pm ] |
is that what your dad has on his? #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | caddobrook [ Fri Oct 13, 2017 8:15 pm ] |
nope. http://www.academy.com/shop/pdp/magella ... id=4189176 Lot cheaper..... Had it mounted on the Boat DR rain guard when it was on the briggs. Now on the kawi it is just mounted in on a plastic boat cleat I had laying around that I trimmed up a little.... Not sure any of them are legal due to the 360, but it is what I use.. I have the traditional pole light as well just in case I get called out on it.... It stays in the gun box. |
| Author: | Russ [ Fri Oct 13, 2017 8:40 pm ] |
don't get that light. it's hard to follow at caddo in the dark. poor Arlon wound up IN the trees, not between them [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY] #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | BlueShamu [ Fri Oct 13, 2017 8:51 pm ] |
| Author: | Quack N Stack [ Sun Oct 15, 2017 5:36 pm ] |
| Author: | texritter13 [ Fri Oct 20, 2017 4:27 pm ] |
