It is currently Mon Mar 16, 2026 10:10 pm
Reply to topic  [ 7 posts ]
 Weld on pods?
Post Weld on pods?
Debating getting pods welded onto my hull. Anyone done this? Is it worth it? Pros and cons? I run a 27hp prodrive on a 1752 Alweld. Any advice is appreciated.
Thu Dec 14, 2017 5:01 pm
Post Re: Weld on pods?
yes. no. the juice ain't worth the squeeze.
#TheGhostBoat
Thu Dec 14, 2017 5:16 pm
Thu Dec 14, 2017 6:59 pm
Simply amazing!
Fri Dec 15, 2017 8:17 am
Why would you want pods on a boat that size anyway??? :roll:
Refurbishing a Prodrive
Fri Dec 15, 2017 8:53 am
I had them on a 1648 Lowe with a 35 Mudbuddy. They helped carry the load. The down side I noticed was when I would put the boat in the weeds and try to get it out. When I tried to push it backwards the mud and weeds would build up between the pods making it a real pain to try and back out of the weeds/reeds. I put the same motor on an 1850 Phowler Extreme. For what it's worth, night and day difference. No pods needed and the boat handles the weight of the motor better than the 1648 with the pods.
Tue Dec 19, 2017 8:03 pm
Put pods on similar size boat, same motor, and it completely robbed good water from the prop. Could not get the thing to do above 10mph with 2 guys and dog. Cut the pods off, problem solved.
Thu Dec 21, 2017 6:55 pm
