MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
Please begin entering boat data here!! https://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=17347 |
Author: | dguidry [ Wed Mar 30, 2011 3:46 pm ] |
Post subject: | Please begin entering boat data here!! |
The database is ready. Please click here to view data: Please click here to enter data: |
Author: | msm8281 [ Wed Mar 30, 2011 3:52 pm ] |
Post subject: | Re: Standardization of Who's Got the Fastest Boat? |
you might want to add a knee pad or no knee pad parameter |
Author: | dguidry [ Wed Mar 30, 2011 3:57 pm ] |
Author: | kibb [ Wed Mar 30, 2011 5:07 pm ] |
GTR and FPR are the only needed to apply. All others just go one direction. FORWARD. |
Author: | Barroll [ Thu Mar 31, 2011 9:37 am ] |
Author: | dguidry [ Thu Mar 31, 2011 9:46 am ] |
Its really not about speed. Just trying to do a study on what might make a boat combination more efficient. The title of the thread was just to catch everyone's attention. The data might confirm or refute some propositions about what makes a boat more efficient or faster in any set of parameters one might choose to monitor. You have any suggestions on what parameters I might want to include in addition to those I listed? |
Author: | WestEndAngler [ Thu Mar 31, 2011 10:50 am ] |
1a. Engine: GTR35 1b. Ratio- GTR35 2. 33.5 MPH 3. Average RPM at Average top Speed - 3950 4. Windage: estimate speed or generally describe: calm 5. 220 LBS 6. Current: Estimate or describe: None 7. # of batteries - 2 8. Cooler - 60Q Yetti 9. Cooler Weight - 20lbs + beverages 10. No. of beverage containers - 12pack + couple waters 11. Prop Pitch -10P 12. Other: estimate weight - anchor (10lbs) + flotation & who knows how much that weighs 13. Water Conditions: calm 15. Length of Boat - 18' LOA 16. Width of Bottom - 60" 17. Flat or semi-v - FLAT BOTTOM 18. Manufacturer or Custom Builder - GATOR-TAIL 19. Long or short transom - LONG 20. Pods or no pods - HUNT DECK 21. Trim tabs or no trim tabs - N/A 22. Console or tiller - Tiller 23. Wood or Aluminum - ALUMINUM 24. Trolling motor or not - Removed 25. Deck or no deck - Front extended deck 26. Storage: gun box - misc. tools & equipment + winch 27. Other factor you wish to include which might affect speed - N/A 28. Stock motor - NO 29. Heads Decked xxx or stock - STOCK 30. Performance muffler type or stock - MM - Baffled single outlet 31. Performance carb type or stock - Mikuni 32. Cam type or stock - BPS cam 33. Propeller manufacturer - Powertech with some added help from Baumann Propellers |
Author: | BradS [ Thu Mar 31, 2011 11:49 am ] |
Im gonna go out on a limb here and say Turbodrive has the fastest boat |
Author: | dguidry [ Thu Mar 31, 2011 12:15 pm ] |
Go here to view data: Go here to enter data: |
Author: | dguidry [ Thu Mar 31, 2011 12:17 pm ] |
ttt |
Author: | MaXXis85 [ Thu Mar 31, 2011 12:28 pm ] |
This will help you guys out. I just used Coe's numbers cuz he posted them up. I want to show you guys an example http://www.culverprops.com/pitchselection.htm Fill this end and it will tell you your pitch of a prop for your given RPM, desired speed, given prop Length (diameter), and Gear ratio. Use 1.2:1 for GTR. you guys will be surpised. Below is a cliffs notes, but plug in those numbers and you can figure out wos Lying! Engine RPM 4000 MPH 30 Reduction Ratio 1.2:1 Prop Length 12 Guess what it calculates you need a 10 pitch prop that assumes NO SLIP. We all know that there is slip in a prop Just saying that it is hard to belive that a boat will travel 33.5" MPH at 3950 RPMS with a 1.2:1 reduction ratio with a 12x10 prop without slip.. Even though slip is ALWAYS present |
Author: | WestEndAngler [ Thu Mar 31, 2011 12:32 pm ] |
James ran a 12P and couldn't turn it... I am having an 11P made right now for me... I run better with an 11P. We have been messing with the thickness of the trailing edge of the blade, adding thickness instead of honing it down like powertech does will drop your top end down but prop will last longer in the stuff... just something to think about... |
Author: | dguidry [ Thu Mar 31, 2011 12:33 pm ] |
Author: | dguidry [ Thu Mar 31, 2011 2:16 pm ] |
OK, I've put up links to enter and view data. Please start entering data so I can test the links. Thanks. Go here to view data: Go here to enter data: |
Author: | take'emgator [ Thu Mar 31, 2011 2:24 pm ] |
Author: | BradS [ Thu Mar 31, 2011 2:25 pm ] |
And why not --- just cause its not running right now or did they do something to slow it down LOL |
Author: | dguidry [ Thu Mar 31, 2011 2:30 pm ] |
Post subject: | Re: Please begin entering boat data!!! |
Author: | WestEndAngler [ Thu Mar 31, 2011 2:35 pm ] |
Done. |
Author: | dguidry [ Thu Mar 31, 2011 2:48 pm ] |
Post subject: | Re: Please begin entering boat data here!! |
The interface is working perfectly!!!! |
Author: | dguidry [ Thu Mar 31, 2011 7:44 pm ] |
Tony B was helpful in making this boat data entry thread a sticky post in the reviews section. Please take a moment to go to the top of this thread and enter your rigs data. It's pretty detailed and once I get enough data I'll analyze it and report trends regarding performance versus modifications and configurations. Your cooperation is appreciated. |
Author: | swamphonkey [ Thu Mar 31, 2011 8:52 pm ] |
I posted this junk on your site einstein! I'm kinda confused though are we building drag boats or boats to get us where the ducks are? And who really wants to hit a stump in the dark doin 40mph! Or are we building a Jeff foiles get away boats? Hmm.... |
Author: | dguidry [ Thu Mar 31, 2011 9:11 pm ] |
TTY |
Author: | Gigafowl [ Thu Mar 31, 2011 9:15 pm ] |
Author: | WestEndAngler [ Thu Mar 31, 2011 9:27 pm ] |
Can you edit my information so that it adds a 10lb anchor & chain along with flotation... |
Author: | dguidry [ Thu Mar 31, 2011 10:09 pm ] |
Author: | dguidry [ Wed Jun 01, 2011 11:57 am ] |
We are getting very good entries in the boat data table. Please add your boats data so so everyone will know all the details and maybe put the information to good personal use when making a decision on what to buy or modify. See details below in my signature. thanks for everyone who has cooperated so far. |
Author: | autogateman [ Wed Jun 01, 2011 12:10 pm ] |
Author: | CLICKSTER [ Tue Jul 12, 2011 6:55 am ] |
How can i go back and edit my data? |
Author: | dguidry [ Tue Jul 12, 2011 7:02 am ] |
Author: | CLICKSTER [ Tue Jul 12, 2011 1:39 pm ] |
speed 24 @ 3980rpm pasanger weight 225 |
Author: | dguidry [ Tue Jul 12, 2011 2:04 pm ] |
Author: | CLICKSTER [ Tue Jul 12, 2011 2:07 pm ] |
it was just me with beer |
Author: | dguidry [ Tue Jul 12, 2011 2:12 pm ] |
Author: | CLICKSTER [ Wed Jul 13, 2011 6:09 am ] |
brandon click |
Author: | Quack Stackin [ Mon Aug 29, 2011 8:29 pm ] |
Could you delete my first entry, thanks |
Author: | Quack Habit [ Fri Jan 20, 2012 3:23 pm ] |
New here, and I'm impressed! I'm getting ready to build a new boat, so seeing what everybody else is running is a great help. Thanks dguidry! |
Author: | dguidry [ Fri Jan 20, 2012 11:19 pm ] |
Author: | dguidry [ Sun Feb 12, 2012 10:58 am ] |
Just a reminder to post you boat's data in the database below my signature if you have new rig or haven't post your old rig's data yet. Now that season is over thought I'd remind everyone. The database is proving very useful to those contemplating new rigs and options. |
Author: | gator22 [ Sat Jul 13, 2013 7:18 pm ] |
Well dg Im fixen to up grade my paddle to a stage 3 paddle. Sent from my SCH-I535 using Tapatalk 4 Beta |
