Melnmo
 Spud Hole Winch Power Supply?
For those of you that have a movable winch, how are you supplying power and what receptacle types are you using? I'm planning mounting my winch with a simple rod welded to a plate that can be moved from spud hole to spud hole bow to stern. My original plan was to wire a male trolling motor connector to the winch, beef up my trolling motor supply cable and use the existing trolling motor receptacle for the winch. I really don't know the best way to tackle power to the winch on the stern.
After some research, it appears that the trolling motor receptacles aren't rated for the amperage needed. So.. now I'm just considering making a cable long enough to reach anywhere in the boat. If I go this route, where do I mount the solenoid, circuit breaker, etc..? I'd really like to make this as clean/easy as possible.
I've done some searching and know many of you have been down this road. Any input/suggestions?
| Tue Oct 11, 2016 1:52 pm |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
 Re: Spud Hole Winch Power Supply?
I use this. Its overkill for the 3,500lb winch in the boat, but I keep it in my truck tool box and use it for a 10k receiver winch as well. You can buy just the quick connects. Have a set on the winch, and coming off the solenoid. https://www.amazon.com/Tuff-Stuff-Permi ... winch+wire
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Tue Oct 11, 2016 1:56 pm |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
I mounted the winch solenoid switch next to the battery and hardwired the cables, switch wire and switch. All of it is located under the foredeck overhang. I used 4ga welder cable with welder quick disconnects (hobart style) on the cable ends and with short leads made up on the winch. The cable and switch circuit are long enough to reach all four corners of the boat. I coil them up together and bungee them to the battery box when not in use, and either store the winch in a spud mount, or put it in one of the storage boxes.
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
| Tue Oct 11, 2016 5:02 pm |
Frog
I use my trolling motor plug in the bow and have an extension (#6 wire) for the stern. Never have had to use it cuz....l have GatorGlide on the bottom
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
| Wed Oct 12, 2016 5:13 am |
bschwartzenburg
I use the trolling motor plugs as well. The plate I have my winch mounted on has all of the wiring and solenoid mounted on the bottom side. Never had any problems.
And I have gator glide on the bottom!!!
_________________ 17 x 44 Southfork Mud Hull with a 25hp Big Block Mudbuddy
| Wed Oct 12, 2016 11:53 am |
Melnmo
Thanks for the replies, I'm going to try and knock this out this weekend so hopefully all goes well.
On another note, I called Superwinch with a wiring question and surprisingly an actual human answered the phone. He was courteous, knowledgeable and most of all, very helpful. I'm hopeful that I won't ever need them again but so far I'm impressed with their customer service.
| Fri Oct 14, 2016 6:48 am |
koda4u
Joined: Wed Jan 21, 2009 10:43 am Posts: 72 Location: Tennessee with a Louisiana wife...
Post some pictures of your process if you have time. I have been planning this for a while too.
_________________ 18x54 CC Gatortail Huntdeck w/35GTR MM double barrel X Go Devil 16x56 w/35 SDGD -sold
| Fri Oct 14, 2016 6:01 pm |
dead animal
I use welding cable and a plug in connector I got from the 18 wheeler parts store. it's worked for 5 or 6 years with no problems, and I winch alot.
| Sat Oct 15, 2016 7:21 am |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
Could you use a set of quality jumper cables? Seems like an easy option
| Sat Oct 15, 2016 1:35 pm |
Melnmo
| Sun Oct 16, 2016 10:07 am |
koda4u
| Sun Oct 16, 2016 7:40 pm |
Melnmo
| Fri Oct 21, 2016 11:58 am |
TPerkins
Very well made and thought out setup. If I were to ever do one for my current rig it'd be just like this.
| Fri Oct 21, 2016 12:12 pm |
HOTSAUCE170
Joined: Thu Jun 05, 2014 11:44 am Posts: 1685 Location: Lake Blackshear,GA
_________________ I named my boat RIANNA cause it gets beat up all the time
| Fri Oct 21, 2016 1:00 pm |
