It is currently Tue Mar 17, 2026 10:35 am
[ 9 posts ] |
Duck-killa
Joined: Sun Apr 08, 2012 10:48 pm Posts: 154 Location: Cut Off, LA
 Bouncing boat
Have a 2010 gatortail boat and motor, boat is 16x54 gator hull, my boat has always bounced when trimed pretty close to all up and trimmed all the way up, but that's when I see my best speed before it starts bouncing, now with 1 person on the front deck it runs great and doesn't bounce and I can run it trimmed all the way up. The old owner always ran with the motor in the bottom pin hole. And when I received the boat I moved it too the middle hole cause I was seeing better speed. Like I said with 1 person on the front deck on the front deck it runs great but just me i bounce too much, I was wondering what these wedges welded on the bottom were for and if I should cut them off cause that's what's causing the problem ? Or cut these off and get a welder to put a bead on the bottom or weld some trim tabs ?
_________________ Delta lvl 3 GTR with MAC 16x54 Gator hull
| Sat Jul 01, 2017 8:36 pm |
Duck-killa
 Re: Bouncing boat
It won't let me post a picture with it but it's 2 4x4 wedges welded onto the bottom
| Sat Jul 01, 2017 8:37 pm |
brycecheramie
 Re: Bouncing boat
The wedges are probably there to help it not bounce as much.
You should put your gas tank and battery up front.
| Sat Jul 01, 2017 8:40 pm |
Duck-killa
 Re: Bouncing boat
I've got a 15 gal gas tank in the front
| Sat Jul 01, 2017 9:13 pm |
brycecheramie
 Re: Bouncing boat
Well damn. With the speeds you're getting, that boat is just too short.
| Sat Jul 01, 2017 9:15 pm |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
 Re: Bouncing boat
Put a fat chick up front.
| Sat Jul 01, 2017 9:37 pm |
kib876
Joined: Tue Dec 15, 2009 8:16 am Posts: 612 Location: Orange, Texas
 Re: Bouncing boat
What he said ..
| Sun Jul 02, 2017 7:58 am |
Mallards Only
Joined: Wed Jan 14, 2009 9:23 pm Posts: 404 Location: Idaho
 Re: Bouncing boat
3 options:
1. Always run with another person.
2. Weld some trim tabs.
3. Get an 18' boat
_________________ 1860 Prodigy
| Mon Jul 03, 2017 11:26 am |
50fps
 Re: Bouncing boat
Grab some sand bags.
| Tue Jul 04, 2017 3:59 pm |
[ 9 posts ] |
