It is currently Tue Mar 24, 2026 8:17 pm
[ 6 posts ] |
2015 Gtr 35 mikuni/e-pump install ?
Pintail1992
Just received my carb kit and and exhaust from Delta. Delta said I didn't have to but recommended that I run an E-pump. Any of you guys have some insight or any pics of how you mounted your E-pump to the motor??
| Thu Oct 12, 2017 11:43 am |
Russ
 Re: 2015 Gtr 35 mikuni/e-pump install ?
I run mine 6-12" from the gas tank through (currently) 8' of fuel line to the engine. I was running about 15', but it was time to put new line on and didn't use as much. It's not vibrating with the engine with it in the boat.
| Thu Oct 12, 2017 11:47 am |
Pintail1992
Ok thanks. So you did you bypass your manual pump all togheter or leave it inline. May be a dumb question but I'm new to do any mods on these motors.
I see a lot of guys say you don't need to run an e-pump But I got it so I figured I would give it a shot
| Thu Oct 12, 2017 12:09 pm |
Russ
Never had a stock pump installed. Built this engine from a parts engine and some aftermarket additions myself.
| Thu Oct 12, 2017 12:31 pm |
MaXXis85
if your stock fuel pump is working fine, You will be fine.
| Fri Oct 13, 2017 6:01 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
I got 12-15 ft of fuel line(5/16), impulse type pump, tank built in to console, primer bulb and fuel filter within the 1st 2 ft., works good for me, and I am running a mikuni carb. with 3/8 line in my other boat had issues kept losing prime at low speeds.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Fri Oct 13, 2017 8:01 am |
[ 6 posts ] |
