It is currently Sat Jul 12, 2025 9:03 am
Reply to topic  [ 10 posts ]
 need help
Post need help
:roll: i need some advice i built this rig and put it in for the frist time and it wont get on pad .yes it is a 33 hp generac .i have a 38 on top and 50 on the bottom.a 27" outdrive im a big dude but damn i would think it would get it on pad. the boat is a 17' xpress 50" bottom 72" beam it is a bass boat that i hulled out .where do i go from here? boat doc said go to a 52 on bottom and im sure that will help but i dont think that will be enough thanks :?:
17 54 custom /35 mb hd sport
Sun Jul 15, 2012 4:52 pm
Post Re: need help
Are the transom heights matched?
Are your rpm's where they should be?
What is the prop doing?
You really described it vaugley so I cant give an answer, but your best bet is to put a 90 Yamaha on that boat and get a real Mud-Hull for your Mudmotor.
Sun Jul 15, 2012 5:36 pm
Post Re: need help
yes they match,they r 3500 rpm it is digging. and i dont wont a narrow boat .and i like just having one boat .thanks for your help.
Sun Jul 15, 2012 5:45 pm
Post Re: need help
Have you messed with trim settings any?
Start trimmed all the way down and slowly trim up until it finds its sweet spot.
What is your thinking behind a mud-boat being narrow? They make mudboat hulls that size or bigger everyday. But that ribbed mod-v hull will never run right.
Sun Jul 15, 2012 6:23 pm
Post Re: need help
i didn t know thay made a wide one who makes it . and this is a hyper hull dont know if it is classified as a ridded. i my need to sale the motor and get a gtr.
Sun Jul 15, 2012 6:33 pm
Post Re: need help
I'm not sure on a generac but 3500 isn't very much. Should be over 4k. Also you seriously need to measure your transom height. Its a bigger deal then you think. Also I run a mud hull along with countless others that are wide mine is 54" with a 72" beam. It will definatly work better on mud hull good luck
Sun Jul 15, 2012 6:51 pm
Post Re: need help
ok thanks. the transom is 21" and the motor is a tall one top cover has 8 bolts in it .is your boat still for sale
Sun Jul 15, 2012 7:00 pm
Post Re: need help
Possibly man. I've got bow fishing set up on it now but I might make a deal. Also your transom will work the best at about 19.5 sounds dumb but I've been down that road. A 32" drive will defiantly help with that
Sun Jul 15, 2012 8:27 pm
Post Re: need help
ok thanks i think i wil get a mud hull
Sun Jul 15, 2012 9:02 pm
Post Re: need help
Ok let me know if you're interested
Sun Jul 15, 2012 9:13 pm
Users browsing this forum: Majestic-12 [Bot] and 97 guests
