It is currently Tue Jul 08, 2025 3:56 am
Reply to topic  [ 15 posts ]
 1645 swf excel with 35HD speed issues
Post 1645 swf excel with 35HD speed issues
Hey guys. Question here. I am running a 1645 SWF excel with a 35 HD... I feel as if this thing is loosing speed....and should just plain be a little quicker.
I noticed the other day I only got 24 with just me gas and one other guy. Both of us are only 150 a piece... I swore I use to get high 20s no problem. 27 or so.
The motor revs up effortleslly to its full rpm range but has a rough idle. Going to do a tune up tomorow. My prop somewhat sounds like its cavitating alot (but it could be me just thinking this)
The prop is somewhat sharp towards the very outside of the ear and I was told it is "scalloped" and I am pretty this could cause my speed loss.
Opinions?
Sun Aug 18, 2013 7:20 pm
Post Re: 1645 swf excel with 35HD speed issues
Do you have any big dents in the bottom by your transom?
Check your neutral rpms at full throttle and set them to 4300
Check your carb to make sure it is opening all the way.
Sun Aug 18, 2013 7:23 pm
You answered yourself. If prop is sharp along the tips that means it's burnt up.
Sun Aug 18, 2013 7:27 pm
No dents and my rpm range is 3900 to 4100 wide open.
So that's the case? The prop is shot?
Sun Aug 18, 2013 8:02 pm
39-4100 in neutra? If so, bump it up to 4300.
Sun Aug 18, 2013 8:07 pm
yessir clutch disengaged. How do I do that? I know how to work on stuff just not sure how to do it one of these never worked on one.
Mon Aug 19, 2013 7:18 am
Mon Aug 19, 2013 8:23 am
can someone that runs this setup chime in? I got a brand new prop today as mine was shot and only hit 26 solo. Yesterday with the old prop only hit 24 solo
Fri Sep 06, 2013 4:15 pm
Have you checked your rpm in neutral
Fri Sep 06, 2013 4:29 pm
Just over 4100. I dont beleive 200 rpms would cause a significant decrease. I have done numerous searches and cannot find much information on this setup and its speeds from other guys.
Fri Sep 06, 2013 6:44 pm
When you're running the boat what rpms do you turn?
In all actuality, it's probably your valves leaking. As far as speeds, friend of mine had one before he got his PD rig. Stock with a good prop, he was a steady 29mph solo until he put a huge dent in the boat.
Fri Sep 06, 2013 6:55 pm
Valves leaking? The motor only has 80 hours on it...
It turns like 3800 in the water... Motor revs up effortlessly and sounds solid. Feels like it makes good power just I think it should be faster. Would not be that big of a deal if I didnt see other guys with the same setup running quicker.
Sun Sep 08, 2013 3:18 pm
If you dont think 200 rpms would make a difference, then turn your motor down to 3900 rpms in neutral.
Sun Sep 08, 2013 3:23 pm
Well will 200 rpms make a difference?
Sun Sep 08, 2013 6:24 pm
1 mph at least
Sun Sep 08, 2013 7:05 pm
Users browsing this forum: No registered users and 75 guests
