It is currently Sun Jul 06, 2025 1:11 am
Reply to topic  [ 19 posts ]
 Which ones faster???
Post Which ones faster???
Which one's faster on a 15-42 flat Bottum jon?20hp four stroke outboard or a 23 horse SD.
Sun Nov 17, 2013 3:11 pm
Post Re: Which ones faster???
Outboard
Sun Nov 17, 2013 3:24 pm
Where do you plan on running it? Open water or mud and weeds. They are not designed to compete. Which hammer is best... claw or ball peen?
Sun Nov 17, 2013 4:17 pm
Sun Nov 17, 2013 4:32 pm
Well I have two hulls so I'm going to have one of each. I'm just wondering if I'm going to gain any speed on the motor change
Sun Nov 17, 2013 5:39 pm
A 20 outboard will plain smoke a 23 SD in open water.
That 23 SD would run better on a boat about 2' longer.
Sun Nov 17, 2013 6:07 pm
The 20hp outboard is going to be more efficient. Less slippage of the prop bc it is fully submerged. More efficient thus faster and prolly will carry a load better too. It's almost not fair to compare the two. An outboard won't last in shallow water muddy bottom. A mud motor can't compete with an outboard of the same hp in deep water. But your trying to compare apples and blankets. Depends on what's best for your area.
Mon Nov 18, 2013 8:04 am
I know the outboard is more efficient and thus faster in open water. The reason I ask is because I think I'm selling my 12 hp copperhead and putting my 20 hp outboard on the boat that the copperhead was on. I then want to buy a 23 sd for the boat the outboard was on. Are the speeds of the 23 sd gonna even compare with the 20 hp on the same boat in open water? Keep in mind it's a 15-42 flat Bottum Jon that ways about 210 lbs
Mon Nov 18, 2013 9:56 am
I'm pretty sure a 20 hp outboard will out run a 23 sd. A 23 may run around 25ish if your real lucky. And when you add weight you will fall off. Outboard won't be as probe to fall off as much whe you add more weight.
Sent from my beeper.
Mon Nov 18, 2013 10:14 am
So if I can get 21 mph with my 12hp copperhead, do you think I will get 25 with a 23hp sd on the same rig
Mon Nov 18, 2013 11:50 am
I think so.
1846 GTB with GTR 35
Mon Nov 18, 2013 5:18 pm
So which one do I go with, copperhead 23 or MB23lite
Mon Nov 18, 2013 5:32 pm
Go with the copper head. I ran a mini lite for 120 hours and it had never given me a problem. But all mud buddys are powder coated and have steel mounting brackets. The steel will start rusting and the powder coat will start flaking off. Also the steel makes it a little heavier than the copperhead. Plus better customer service. I haven't owned a copper head but called Gil to ask a few questions ,and he fully explained everything and made sure he did all he could do via the phone. Hope this helps
1648 gd hull flying in front of a stage 3 with fpr
Mon Nov 18, 2013 6:14 pm
How do they two compare as far as speed and durability and what not?
Mon Nov 18, 2013 6:45 pm
durability is probably gonna be about the same. Speed should be similar as well. mine was modded and would haul the mail for a motor of this size. never ran it stock
Mon Nov 18, 2013 6:56 pm
I appreciate it. Idk why but I've been reading on here that the copperhead is faster than the mudbuddy. Idk how they could be much different with the same engine
Mon Nov 18, 2013 7:35 pm
Weight, gearing, and prop.
Mon Nov 18, 2013 7:36 pm
I ran a mini and it was a good motor. I also run a HD sport frame now. It is also a good motor. I will not own another Mudbuddy simply because there service is awful.
Mon Nov 18, 2013 7:41 pm
That seems to be a consistent thing with mudbuddy. That's unfortunate. We'll see, I don't need one till after duck season. I gotta sell my 12hp copperhead first.
Mon Nov 18, 2013 7:47 pm
Users browsing this forum: No registered users and 139 guests
