It is currently Fri Jul 18, 2025 7:13 am
Reply to topic  [ 20 posts ]
 Is there anyway to better my 15hp longtail?
Post Is there anyway to better my 15hp longtail?
Ive got a 15 hp go devil long tail, and im just wondering if there is any at home, or even purchased mods i could do or buy to better its performance, and for god sakes its speed? Or just anything at all to better what it is now?
Tue Dec 28, 2010 10:31 pm
Post Re: Is there anyway to better my 15hp longtail?
Yeah you can spend $2,500 on heads, cam, exhaust, carb, intake, and prop for an increase in hp or you can just sell it and buy a big block surface drive.
Wed Dec 29, 2010 4:25 am
I was just seeing if there were any modifications like cutting 2 1/2" holes in the stock exhaust and welding some pipe to each for a increase in exhaust flow
Just little things like that
Wed Dec 29, 2010 6:24 am
check out some of the go cart sites, google "affordable golf karts parts" i think, and they give instructions on how to remove the governor, and then mod the air filter and exhaust.
be sure to install a tacometer if you remove the governor so you dont blow it up though
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Wed Dec 29, 2010 2:17 pm
just do what quack said to do.
Team Arc Angel Bowfishing
Wed Dec 29, 2010 2:18 pm
what type of speed are you getting out of it now
12 ft 11hp longtail
Merc 225hp TR20
Wed Dec 29, 2010 2:27 pm
So the go devils have a governor??
With just me it'l get up to about 12 to 14 maybe, with a 16ft all aluminum flatbottom
Wed Dec 29, 2010 2:42 pm
cut the shaft 32 inches, buy some timing gear pulleys, with 1.35:1 gear ratio. Have a housing built for gears, then bolt shaft to housing, Get a surface prop and VOILA!!! surface drive. Its all better then. If it was only that easy right.
Wed Dec 29, 2010 2:47 pm
Profile YIM
Lol I plan on getting a surface drive net year im only 18 so moneys slim right now. I just wanna see if I can get more outa this little thing while I've got it
Wed Dec 29, 2010 6:16 pm
your never gunna get it to run with the big motors, why spend money to gain a couple mph just to make it more unreliable?
Wed Dec 29, 2010 7:10 pm
Thu Dec 30, 2010 8:35 pm
I plan on getting a sd next year I was just checking if there was anything that I could do to better what vie got now I always trying to take a step forward
Sun Jan 02, 2011 5:42 pm
a new prop and just keep up on the maintenance and you should be fine. dont worry about the speed with such a small hp motor..
Tue Jan 04, 2011 6:44 am
I've got a real small 3 blade prop right Now that I'm not go thrilled with. Think it would be a litle faster and go through more with a little bigger 2 blade?
Tue Jan 04, 2011 4:52 pm
Do you have a tach on your motor? have you gps'd how fast your going now?
Wed Jan 05, 2011 1:40 am
No, and no
Wed Jan 05, 2011 12:27 pm
Start with doing both of those..
Thu Jan 06, 2011 1:28 am
What's the tachometer good for?0
Thu Jan 06, 2011 9:58 am
Lets u know if your motor is running in the right rpm range. Can give you hints that your compression may be low, or time for a new prop...
Also good for keeping track of your hours so you know when to do your scheduled maintenence.
Thu Jan 06, 2011 1:21 pm
I gotcha.. Ima have to invest in one
Thu Jan 06, 2011 1:41 pm
Users browsing this forum: No registered users and 122 guests
