It is currently Thu Jul 17, 2025 9:15 pm
Reply to topic  [ 18 posts ]
 pro drive help
Post pro drive help
Any suggestions in why my motor is rubbing against this piece? I just notice this today and it only rubs if you turn it to the right if you are inside looking at the motor.
Thanks for the help.
Mon Aug 29, 2011 2:04 pm
Post Re: pro drive help
Because you bent it from tilting the motor to far back. Cheater pipe and elbow grease.trim all the way down, Slide cheater pipe over it, pull back. If you need more weight get someone to stand on the cavitaion plate to prevent you from lifting the motor. I did mine while trailering it down highway 3127between Vachiere and boutte.
Mon Aug 29, 2011 2:09 pm
That sucks, but I guess is a easy fix. I try from keeping it from bouncing so much when trailering, I use a Transom saver, a ratchet tie down to a brace of the boat, but it still freaking bounces.Thanks for the suggestion.
Mon Aug 29, 2011 2:23 pm
I am cutting mine to the same hieght of the other one. The only reason that one is longer is because of that little hhok thing they had to hold the motor up. I don't use that so i am cutting it off i hope it works
Mon Aug 29, 2011 2:54 pm
I just hope I don't pull back to much where it looks like crap. Lol.
Mon Aug 29, 2011 2:56 pm
Mon Aug 29, 2011 3:55 pm
Post pro drive help
You got good advice. Have someone stand on the cav plate, and bend it out with a cheater pipe. As far as it being a problem, talk to Peck about it. At one point back in the day I sent my tower housing in to him an he fixed it for me permanently. With all the talk of transom savers and straps and stuff, you really need to be careful how you do that. It could cause a lot more problems than you think. Trim the motor up against the reverse block and leave it. Don't strap it down.
24x60 Dual Prodrives
Mon Aug 29, 2011 4:26 pm
I cut mine off the same height as the other one. Problem solved.
Mon Aug 29, 2011 6:53 pm
What the hell is that for?
Mon Aug 29, 2011 7:34 pm
thats where you ty of the gtr boats that are stuck
:lol: :lol: :lol: :lol: :lol:
driving a gd in ur lake
and i aprove this message
Mon Aug 29, 2011 8:08 pm
Put yer face in the myrtles.
Mon Aug 29, 2011 8:09 pm
Tue Aug 30, 2011 6:32 pm
Tue Aug 30, 2011 6:37 pm
Cutting it off does get it off the motor. I don't understand how that piece got bent. If that is bent, something else has got to be wrong too, shouldn't it?
18'x54"CC Hanko/ 36PD
Tue Aug 30, 2011 9:34 pm
Wed Aug 31, 2011 11:02 am
I put a piece of 3/4 black water hose over those rods on mine so it dont hit the roller so hard, seems to have helped it from hitting so hard going over logs and chit
Wed Aug 31, 2011 11:12 am
I bent mine bad a couple years ago when I hit some underwater pipe running wide open. I just cut it down the same height as the other one. It acts as a stop on the motor when u hit something bad. Without it u and the motor could make friends with each other inside the boat.
Tue Sep 13, 2011 5:37 pm
It may not be bent. You may have worn tower bushings. This was my case.
Wed Sep 14, 2011 11:34 am
Users browsing this forum: No registered users and 71 guests
