It is currently Mon Jul 14, 2025 8:13 am
Reply to topic  [ 10 posts ]
 Gatortail on PD hull?
Post Gatortail on PD hull?
Anyone put a Gatortail on a pd hull? I heard the transom angle of the PD is different than the GT boats. If I decided to put a GT on my 1854 Pd, would I lose performance due to transom angle?
Sat Mar 10, 2012 5:13 pm
Post Re: Gatortail on PD hull?
you can shim it
Sat Mar 10, 2012 5:14 pm
If it is a short transom boat and let them raise the transom, maybe they can change the angle. I think they changed it on my GD hull when they raised it.
Sat Mar 10, 2012 6:21 pm
No, I have the tall transom PD
Sat Mar 10, 2012 7:36 pm
Shim it
17x48 extreme stage 2 GTR
Sat Mar 10, 2012 8:16 pm
There are wedges made for changing the transom angle. They have been used for years on bass rigs to help out on the hole shot. Theirs a sponsor on here that I bet can make you some if you can't find them.
Sun Mar 11, 2012 12:23 pm
Sun Mar 11, 2012 12:39 pm
I suspect you will be able to trim higher but perhaps not low enough. I imagine the gt guys would know. I have a pd on a gt hull and have had several pd hulls with pd motors. I can trim further down on the gt hull. not as far up. I have the full range needed and it works great just doesn't trim as high as when I had a pd hull. I had a manual pd on this hull and it did not trim high enough. It didn't have reverse either. it was a good excuse to order a new 36 with trim and reverse.
****The manual trim situation could have been corrected with shims and/or a bigger roller on the pd. After running several with trim and reverse I hated not having either and jumped at the chance to sell it after a few hours of use.
Tue Mar 13, 2012 7:34 am
Tue Mar 13, 2012 1:03 pm
I got a boat with what i think is a 15* Tansom angle and i have a Gator Tail. It runs great. I just cant trim down as far as a GT boat with a 20* transom.
Tue Mar 13, 2012 1:05 pm
Users browsing this forum: No registered users and 68 guests
