It is currently Sat Jul 12, 2025 7:58 am
[ 5 posts ] |
Which grease seals for MM build?
Kendall Steffensen
Joined: Fri Jan 11, 2013 2:36 pm Posts: 4 Location: Nebraska
Hi,
Several posts point me towards mcmaster.com for grease seals, but there are about a dozen choices on the site.
Which type of grease seals do I need to match with brass bushings?
Thanks, Kendall
Sat Jan 26, 2013 8:00 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
 Re: Which grease seals for MM build?
if it was me i would get away from lip seals all together and get you a bearing isolater (inpro). no contacting parts, reuseable, never need to replace.
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Mon Jan 28, 2013 2:35 pm |
Kendall Steffensen
Thank you for the reply.
Reading between the lines, are lip seals what I need to go with brass bushings?
Can you point me in the direction of a bearing isolator, I would like to check out that option.
Thanks again, Kendall
Mon Jan 28, 2013 3:12 pm |
OlSchool
Joined: Sun Jan 06, 2013 4:24 pm Posts: 384 Location: Louisiana
Kendall, you cannot use bearing isolators on a mud motor. You must use a lip seals to hold water out. You need to know your shaft diameter and the bore you wish to press the seal into. http://www.timken.com/en-us/products/se ... ature.aspx
Mon Jan 28, 2013 7:29 pm |
Kendall Steffensen
OlSchool,
Thank you, your help is appreciated.
Have a great day, Kendall
Tue Jan 29, 2013 9:02 am |
[ 5 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 92 guests |
