It is currently Sat Jul 12, 2025 2:43 pm
Reply to topic  [ 5 posts ]
 Which grease seals for MM build?
Post Which grease seals for MM build?
Hi,
Several posts point me towards mcmaster.com for grease seals, but there are about a dozen choices on the site.
Which type of grease seals do I need to match with brass bushings?
Thanks,
Kendall
Sat Jan 26, 2013 8:00 pm
Post Re: Which grease seals for MM build?
if it was me i would get away from lip seals all together and get you a bearing isolater (inpro). no contacting parts, reuseable, never need to replace.
Mon Jan 28, 2013 2:35 pm
Thank you for the reply.
Reading between the lines, are lip seals what I need to go with brass bushings?
Can you point me in the direction of a bearing isolator, I would like to check out that option.
Thanks again,
Kendall
Mon Jan 28, 2013 3:12 pm
Kendall, you cannot use bearing isolators on a mud motor. You must use a lip seals to hold water out.
You need to know your shaft diameter and the bore you wish to press the seal into.http://www.timken.com/en-us/products/se ... ature.aspx
Mon Jan 28, 2013 7:29 pm
OlSchool,
Thank you, your help is appreciated.
Have a great day,
Kendall
Tue Jan 29, 2013 9:02 am
Users browsing this forum: No registered users and 108 guests
