Dane
 losing speed
I have 2005 gtr with a stage one and started noticing a drop in my top end used to run 29-32 now only getting between 22-24 running 3850 rpms. Would a worn down prop cause this?
Mon Nov 04, 2013 3:44 pm |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
 Re: losing speed
Yes
_________________ Gator tail
Mon Nov 04, 2013 3:58 pm |
Westi
Joined: Fri May 29, 2009 2:53 pm Posts: 1006 Location: TEXAS
 Re: losing speed
Worn prop, hooks in the boat, OR you just got REALLY fat.
Mon Nov 04, 2013 5:04 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: losing speed
Worn prop usually means more rpms.
Mon Nov 04, 2013 5:16 pm |
deltaduckmaster
 Re: losing speed
If prop is good may want to do a leak down
Mon Nov 04, 2013 5:20 pm |
coupe1975
 Re: losing speed
Picking up fat chick will do it too
Mon Nov 04, 2013 8:18 pm |
OwenDickeson
 Re: losing speed
Check your throttle linkage to make sure you are getting full travel.
Mon Nov 04, 2013 8:49 pm |
Woodiebuster
 Re: losing speed
If its still the original prop it came with, Ive got 20 on a worn prop.
Mon Nov 04, 2013 9:07 pm |
Westi
 Re: losing speed
Mon Nov 04, 2013 10:23 pm |
diddyduck
Joined: Mon Sep 02, 2013 10:24 pm Posts: 2624 Location: ponchatoula, la
 Re: losing speed
Mon Nov 04, 2013 10:43 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
 Re: losing speed
Tue Nov 05, 2013 1:58 am |
banded-mallard
 Re: losing speed
Tue Nov 05, 2013 6:21 am |
cr244
Joined: Sat Jun 16, 2012 9:43 am Posts: 1504 Location: Watoola, Alabama
 Re: losing speed
Tue Nov 05, 2013 7:19 am |
Will
 Re: losing speed
Tue Nov 05, 2013 7:28 am |
Dane
 Re: losing speed
No i didnt get fat. No i didnt pick up a fat chick. No it is not the orignal prop i got a new one 2 years ago normally would get a new one every year but didnt really use it much last year so didnt think it was that worn but pulled a measurement yesterday and prop was 11 3/8 so that is prolly my problem gonna put steel flex on the bottom this week as well as get a new prop or have my old one rebuilt. Thanks for the input though.
Tue Nov 05, 2013 9:13 am |
btmannin
Joined: Tue Jan 15, 2013 5:25 pm Posts: 1723 Location: Oxford/Jackson ms
 Re: losing speed
If you have a worn prop and still only turnin 3850 with a stage 1 motor (I'm assuming that is with an empty boat) then your valves are more than likely leaking as well
_________________ 1436 tin can shoved by a 16 GDLT 16.5x48 running like hell from a built 40 merc
Tue Nov 05, 2013 10:12 am |
OwenDickeson
 Re: losing speed
You have other issues besides a worn prop. My motor is stage 1 and I turn 4600 rpm.
Wed Nov 06, 2013 7:52 am |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
 Re: losing speed
Wed Nov 06, 2013 11:47 am |
OwenDickeson
 Re: losing speed
Wed Nov 06, 2013 1:33 pm |
dfou
 Re: losing speed
Wed Nov 06, 2013 1:48 pm |
Dane
 Re: losing speed
How hard is it to check the valves, what do i need to check the valves and what is the tollerance supposed to be if yall dont mind me asking.
Wed Nov 06, 2013 3:03 pm |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
 Re: losing speed
Wed Nov 06, 2013 3:36 pm |
OwenDickeson
 Re: losing speed
Thu Nov 07, 2013 8:06 am |
Dane
 Re: losing speed
Also did the gear ratio change from 2005 to 2010. Reason being i went from a short transom to a tall transom in 2010. If so could that be why i am not getting the rmps that i used to get??
Thu Nov 07, 2013 10:57 am |
bayouboy
 Re: losing speed
Your ratio is going to be in the pulleys, did you get a new lower unit with the belt housing/new lower pulley?
Thu Nov 07, 2013 6:36 pm |
