It is currently Sat Jul 05, 2025 10:20 pm
Reply to topic  [ 25 posts ]
 losing speed
Post losing speed
I have 2005 gtr with a stage one and started noticing a drop in my top end used to run 29-32 now only getting between 22-24 running 3850 rpms. Would a worn down prop cause this?
Mon Nov 04, 2013 3:44 pm
Post Re: losing speed
Yes
Gator tail
Mon Nov 04, 2013 3:58 pm
Worn prop, hooks in the boat, OR you just got REALLY fat.
Mon Nov 04, 2013 5:04 pm
Worn prop usually means more rpms.
Mon Nov 04, 2013 5:16 pm
If prop is good may want to do a leak down
17x48 extreme stage 2 GTR
Mon Nov 04, 2013 5:20 pm
Picking up fat chick will do it too
Mon Nov 04, 2013 8:18 pm
Check your throttle linkage to make sure you are getting full travel.
Mon Nov 04, 2013 8:49 pm
If its still the original prop it came with, Ive got 20 on a worn prop.
Mon Nov 04, 2013 9:07 pm
Mon Nov 04, 2013 10:23 pm
Mon Nov 04, 2013 10:43 pm
Tue Nov 05, 2013 1:58 am
Tue Nov 05, 2013 6:21 am
Tue Nov 05, 2013 7:19 am
Tue Nov 05, 2013 7:28 am
No i didnt get fat. No i didnt pick up a fat chick. No it is not the orignal prop i got a new one 2 years ago normally would get a new one every year but didnt really use it much last year so didnt think it was that worn but pulled a measurement yesterday and prop was 11 3/8 so that is prolly my problem gonna put steel flex on the bottom this week as well as get a new prop or have my old one rebuilt. Thanks for the input though.
Tue Nov 05, 2013 9:13 am
If you have a worn prop and still only turnin 3850 with a stage 1 motor (I'm assuming that is with an empty boat) then your valves are more than likely leaking as well
Tue Nov 05, 2013 10:12 am
You have other issues besides a worn prop. My motor is stage 1 and I turn 4600 rpm.
Wed Nov 06, 2013 7:52 am
Wed Nov 06, 2013 11:47 am
Wed Nov 06, 2013 1:33 pm
Wed Nov 06, 2013 1:48 pm
How hard is it to check the valves, what do i need to check the valves and what is the tollerance supposed to be if yall dont mind me asking.
Wed Nov 06, 2013 3:03 pm
Wed Nov 06, 2013 3:36 pm
Thu Nov 07, 2013 8:06 am
Also did the gear ratio change from 2005 to 2010. Reason being i went from a short transom to a tall transom in 2010. If so could that be why i am not getting the rmps that i used to get??
Thu Nov 07, 2013 10:57 am
Your ratio is going to be in the pulleys, did you get a new lower unit with the belt housing/new lower pulley?
Thu Nov 07, 2013 6:36 pm
Users browsing this forum: No registered users and 179 guests
