It is currently Thu Jul 03, 2025 5:26 am
Reply to topic  [ 57 posts ]  Go to page 1, 2  Next
 23 MPH gdsd
Post 23 MPH gdsd
I was out by myself running top speed 23 MPH does that seem slow? I have a 16x60 GDSD and a 35hp. Im 250lbs plus decoys and a gun
16x60 GDSD 35HP
Thu Jan 02, 2014 10:39 am
Post Re: 23 MPH gdsd
yes that is about 4 mph to slow. check your prop for wear
Thu Jan 02, 2014 11:26 am
i have about 10 hours on the boat. Do you think it would already be worn that much?
16x60 GDSD 35HP
Thu Jan 02, 2014 5:10 pm
Are you throwing a rooster-tail when you're doing 23? Go-devils are designed to run faster with the motor trimmed down some.
1654 Grizzly
'13 35 GDSD
- My Wife
Thu Jan 02, 2014 5:28 pm
yes i am
16x60 GDSD 35HP
Thu Jan 02, 2014 6:13 pm
Yeah, you'll notice a difference if you trim it down to where you're barely throwing a rooster-tail, but not trimmed down all the way.
1654 Grizzly
'13 35 GDSD
- My Wife
Thu Jan 02, 2014 6:57 pm
ok thanks. ill try it
16x60 GDSD 35HP
Thu Jan 02, 2014 7:23 pm
yup godevils tend to not like being trimmed way up start off trimmed way down and steady trim up to peak speed as you get to high trim her back down a hair and youre good..can also take a marker and mark on the trim knob to make it easier to go right back to the sweet spot if you have to change trim for like mud or anything
Thu Jan 02, 2014 7:46 pm
Tiny Tach helps a lot too.... You should be running 28mph at about 3800 rpms
when properly rigged out.... While on the trailer play with your trim knob and
adjust so that when motor is all the way down the cavitation plate is even with
and in line with the bottom of the hull.... That will give it a deep bite at takeoff
and as you gain speed the trim fins will lift it into the "sweet spot" automatically...
Also get your fuel tanks up front to balance things out properly... Put anything
heavy up there too - guns, decoys, ice chest, etc...
Eat - Sleep - Hunt ! ! !
Thu Jan 02, 2014 9:37 pm
Thu Jan 02, 2014 9:42 pm
Thanks for the tips guys ill try them out saturday. I run out at walisville and old river and ive put it in some shallow stuff so ill take those measurements too.
16x60 GDSD 35HP
Fri Jan 03, 2014 12:42 pm
When mine was stock I ran between 28 and 30 solo. Took my a while to find that sweet spot with the trim for hole shot. Once on step let the trim tabs do their job, just let the handle float in your hand. If it's not trimming out on top take a 24" crescent and play with the tabs. It doesn't take much to make a huge difference. Also play with wight distribution in your boat. And get the flotation outta there.
16x54 GDSD
Simple.....
(was simple, now a rocket)
Fri Jan 03, 2014 5:41 pm
Same problem im having. Several people have been telling me i should be running 27-28mph empty (all 130lbs of me and a gas tank) in my 18x60 but the fastest i've seen is 25mph...and im alittle slower trimed down, fastest speeds i've seen were with a HUGE roostertail.
Wed Jan 15, 2014 7:52 pm
Have ya'll checked your rev limiter ???
You should be able to turn 4100 on the trailer - if not a twist of
a screw on the rev limiter will get you dialed in....
Wed Jan 15, 2014 8:49 pm
Wed Jan 15, 2014 9:15 pm
Wed Jan 15, 2014 9:19 pm
Im getting 4200ish on trailer and 4100 on water? Trimmed down throwing small rooster is the sweet spot on this dixie
Thu Jan 16, 2014 3:12 pm
where is the rev limiter located at
16x60 GDSD 35HP
Fri Jan 17, 2014 2:34 pm
Fri Jan 17, 2014 9:44 pm
Mon Feb 10, 2014 4:30 pm
According to CoCo the 1660 is his fastest boat. I run 24.5 MpH with my 23hp go devil surface drive. Something is not right. I wonder if your trim tabs and trim is set to the correct spot. I would call CoCo and have him trouble shoot with you. You can look on the go devil website and see a 1660 in action. That thing is humping at good speeds
40HP Gatortail
Mon Feb 10, 2014 7:01 pm
Where are you guys located at?
40HP Gatortail
Mon Feb 10, 2014 7:53 pm
Mon Feb 10, 2014 9:31 pm
Im in mont belvieu/old river.
16x60 GDSD 35HP
Tue Feb 11, 2014 9:25 am
If you Gus were from here I would have like to go help y'all out. I would give coco a call at go devil today and he will work the problem out for you. The 1660 with one person should get 29 to 30. The 18 should get 26 to 28. Call him up and he will get it right. Tell the receptionist your issue and she will put someone on the phone.
40HP Gatortail
Tue Feb 11, 2014 9:30 am
Tue Feb 11, 2014 10:41 am
I have a guy coming out to show me some stuff. I think hes a go devil rep. so hopfully we can figure it out
16x60 GDSD 35HP
Tue Feb 11, 2014 12:50 pm
Momma always did call me a Fowlmouth
All the At-a-boys in the world are gone with one Oh-boy
16x44 Geaux Custom, 23HP GDSD, Mikuni Carb, BPS exhaust
12Ft. Critter Gitter Pirogue 1 Wood paddle
Sun Feb 16, 2014 8:38 pm
Put a brand new prop on friday and ran all day saturday in deep water, shallow water, no water, with the wind and never got over 24mph...
Thats an 18x60 boat and a 35hp GDSD with exhaust and carb air intake...
Sun Feb 16, 2014 8:48 pm
I'd take a close look at the bottom of your hull for hooks. Something isn't right with your hull. You sure your motor matches youre transom?
1654 Grizzly
'13 35 GDSD
- My Wife
Sun Feb 16, 2014 8:54 pm
Sun Feb 16, 2014 9:03 pm
Have y'all called Coco yet? I hope you get this worked out.
40HP Gatortail
Sun Feb 16, 2014 9:31 pm
Sun Feb 16, 2014 9:44 pm
40HP Gatortail
Sun Feb 16, 2014 9:49 pm
Sun Feb 16, 2014 9:56 pm
The more you bend the trim tabs the better bite you will get. However, you don't want too much bite. Also those motors do not toss up a rooster tail as high as the other mud motors. Trimming it up too high will kill speed. Your cavitation plate should be flat and no higher than three inches above water. Go devils don't like to be trimmed too high. When riding you should be able to pull the motor out of the water with one hand with some effort. You should be able to lean on it and it not pop out of the water.
Hooking is another thing that causes a boat to slow down. It would be a dent under the boat. A few dents in one spot can cause a hook.
Balancing the weight in the boat can help. If you have too much weight in the back it may not perform that the level you would want it. Move the gas tank up front and make sure the boat is flat on the surface and not leaning to one side.
40HP Gatortail
Sun Feb 16, 2014 10:07 pm
Yea sumthin aint right. I run a heavy ass 18x54 with a stock 35 and I get speeds around 27-28 runnin light in deep water@3850rpms. My sweet spot on my trim is when my rooster tail is dead even with the top of my motor. Like they said above play with the trim tabs and find the spot where the motor wants to "float" (but not blow out). If motor Is blowing out of water @ WOT then u jus barely start bending tabs up a little at a time. A tiny bit of bending makes alot of difference! If u get it adjusted and still dont see any results then its gotta be something with the hull.
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Mon Feb 17, 2014 8:14 am
I've run it with a big ass rooster tail, small rooster tail, and none at all and it hits the same speed either way.
Mon Feb 17, 2014 8:27 am
I ran 24 with my 3 blade prop yes i had a ittle wear but put a tiger big blade on the motor makes a world of a difference brought me up 4-5mph jumps out the hole
Kleibert custom 18/50 push by a 35 gdsd with a lil pixie dust
Mon Feb 17, 2014 12:06 pm
Well i think i found the problem..i do have hooks in the back. Can that be fixed or am i just SOL?
Mon Feb 17, 2014 2:33 pm
Users browsing this forum: No registered users and 159 guests
