It is currently Thu Jul 03, 2025 3:54 am
Reply to topic  [ 14 posts ]
 New tack
Post New tack
Tinny Tack went out.. Best place to get a new one??
GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Wed Apr 09, 2014 4:02 am
Post Re: New tack
Wed Apr 09, 2014 4:45 am
Post Re: New tach
i see a lot of Tiny Tach problems/failure here - is it advised to replace it right off the bat and be done with it?
Wed Apr 09, 2014 6:22 am
Post Re: New tack
Here is a video so you can see it in action.
Wed Apr 09, 2014 7:56 am
Post Re: New tach
Wed Apr 09, 2014 7:58 am
Post Re: New tack
Ive owned 3 GTR's. First one leasted a good while.. 2nd one lates maybe 40hr.. This one lasted 100hr. My luck is not that good it seems. lol
Wed Apr 09, 2014 8:05 am
Post Re: New tack
Only issue I had was moisture getting behind the face and fogging it up. I called Tiny Tach and it's an easy fix. Slip your knife or a very small flat head screw driver under the corner of the clear front "screen" and it'll peel off. Then clean it and carefully put a thin layer of clear silicone around the frame of the cover and put it back on. Resealed from the elements and problem solved.
Wed Apr 09, 2014 8:06 am
Post Re: New tack
I been having mine from 2012.
Has over 500 hrs with no issues
sent from the marsh
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Wed Apr 09, 2014 10:50 am
Post Re: New tack
1648 GDSD 27 GDSD
Thu Apr 10, 2014 3:49 am
Post Re: New tack
mine prodrive is an 08 and tach is still kickin just fine
Thu Apr 10, 2014 8:50 am
Post Re: New tack
Looks like a good one,
Gator tail
Fri Apr 11, 2014 7:32 am
Post Re: New tack
i used a Hardline HR-8061-2 and it worked great. got it from amazon less than 30 bucks. stores max rpm
1754 prodigy- stage 2 GTR
Wed Apr 23, 2014 8:03 am
Post Re: New tack
Some cool new options coming soon from Tiny Tach. I will have a backlit one to check out soon.
If your tach malfunctions, you can peel the transparent label off, then use a razor knife to cut out the sealant on the circuit board. Then bridge the 2 exposed solder points. It will reset. Squirt some silicone in there, replace the label, and ride into the sunset.
Thu Apr 24, 2014 10:32 am
Post Re: New tack
I been asking for a backlit tach for my dual rig so keep us posted
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Thu Apr 24, 2014 6:26 pm
Users browsing this forum: No registered users and 195 guests
