TDUET
Joined: Sun Jul 04, 2010 12:57 pm Posts: 701 Location: Luling, LA (St. Charles Parish)
 New tack
Tinny Tack went out.. Best place to get a new one??
_________________ GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Wed Apr 09, 2014 4:02 am |
banded-mallard
 Re: New tack
Wed Apr 09, 2014 4:45 am |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: New tach
i see a lot of Tiny Tach problems/failure here - is it advised to replace it right off the bat and be done with it?
_________________ that's going itch when it dries
Wed Apr 09, 2014 6:22 am |
banded-mallard
 Re: New tack
Here is a video so you can see it in action.
Wed Apr 09, 2014 7:56 am |
OwenDickeson
 Re: New tach
Wed Apr 09, 2014 7:58 am |
TDUET
 Re: New tack
Ive owned 3 GTR's. First one leasted a good while.. 2nd one lates maybe 40hr.. This one lasted 100hr. My luck is not that good it seems. lol
Wed Apr 09, 2014 8:05 am |
Will
 Re: New tack
Only issue I had was moisture getting behind the face and fogging it up. I called Tiny Tach and it's an easy fix. Slip your knife or a very small flat head screw driver under the corner of the clear front "screen" and it'll peel off. Then clean it and carefully put a thin layer of clear silicone around the frame of the cover and put it back on. Resealed from the elements and problem solved.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Wed Apr 09, 2014 8:06 am |
Bayoublackhunter
Joined: Sat Oct 02, 2010 4:55 pm Posts: 1192 Location: BAYOU BLACK
 Re: New tack
I been having mine from 2012. Has over 500 hrs with no issues
sent from the marsh
_________________ 35gtr on a 1854 Deep South Custom 1436 flat pushed by a 16 GDLT
Wed Apr 09, 2014 10:50 am |
DeltaRunner
Joined: Fri Oct 25, 2013 5:50 am Posts: 482 Location: South Alabama
 Re: New tack
_________________ 1648 GDSD 27 GDSD
Thu Apr 10, 2014 3:49 am |
NORTHFLORIDAFOWLER
Joined: Sun Mar 11, 2012 9:00 pm Posts: 1239 Location: South, Ga/North Fl
 Re: New tack
mine prodrive is an 08 and tach is still kickin just fine
Thu Apr 10, 2014 8:50 am |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
 Re: New tack
Looks like a good one,
_________________ Gator tail
Fri Apr 11, 2014 7:32 am |
krazo
Joined: Thu Sep 06, 2012 8:44 pm Posts: 667 Location: SE Bama
 Re: New tack
i used a Hardline HR-8061-2 and it worked great. got it from amazon less than 30 bucks. stores max rpm
_________________ 1754 prodigy- stage 2 GTR
Wed Apr 23, 2014 8:03 am |
Glade
 Re: New tack
Some cool new options coming soon from Tiny Tach. I will have a backlit one to check out soon.
If your tach malfunctions, you can peel the transparent label off, then use a razor knife to cut out the sealant on the circuit board. Then bridge the 2 exposed solder points. It will reset. Squirt some silicone in there, replace the label, and ride into the sunset.
Thu Apr 24, 2014 10:32 am |
missile
Joined: Mon Jun 18, 2012 7:33 pm Posts: 681 Location: DeKalb, Texas between the rivers
 Re: New tack
I been asking for a backlit tach for my dual rig so keep us posted
_________________ Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's Boat Name: The Gar Barge Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Thu Apr 24, 2014 6:26 pm |
