It is currently Mon Jun 30, 2025 10:32 pm
Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 Gtr prop spinning even in neutral
Post Gtr prop spinning even in neutral
When engine is idling In neutral prop still spins fast. It has gotten worse(faster) spin as time goes on. Only got 81 hours on it.... Is this a sign of something? Is this normal?
Thu Jun 26, 2014 5:36 pm
Post Re: Gtr prop spinning even in neutral
Time to tear into that lower unit
18x48 extreme with 37 gtr
past boats
07 gtr on 16x54 alweld
Thu Jun 26, 2014 6:22 pm
How does the lower unit have anything to do with it? When the clutch is up top? Something is rubbing and not disengaging all the way
Sent from my SCH-I545 using Tapatalk
Thu Jun 26, 2014 6:29 pm
Have you checked belt tension?
Yeah she is kinda tight. Not banjo string tight but she isn't loose... My buddy mentioned that is was a little tight when we installed my engine back to the frame last week
Thu Jun 26, 2014 6:31 pm
My buddy's did that but his lower unit was leaking is yours?
past boats
Thu Jun 26, 2014 6:33 pm
No she isn't leaking
Thu Jun 26, 2014 6:35 pm
Ok, so let me explain why this happens. This has to do with the planetary. When you are in neutral, you are free spinning the planetary. Depending on the thickness of the oil you use in there is going to determine how fast the prop spins. Thin hot oil=less drag and slower prop rpm in neutral, thick cold oil=more drag causing the prop to spin faster. If you know how a planetary gearbox works then you should be able to understand this.
If it's getting faster as you put more time in it then your oil is either leaking out the rear seal or you are using thicker oil as of recently.
Sent from my XT1080 using Tapatalk
17x54 Extreme W/ GTR-35L Stage 1
Thu Jun 26, 2014 6:37 pm
Just take the little plug out and pump fresh grease into the LU. Every gtr spins a little bit in neutral. And no you don't have to tear down and rebuild your LU
HOTSAUCE170 wrote:
Thu Jun 26, 2014 6:38 pm
Yes I understand how planetary gears work and that makes sense. Thanks. Using Castrol 10-w30 same as engine. Is this what yal run?
Thu Jun 26, 2014 6:44 pm
I use the same as my engine oil, but once that rear seal starts leaking, I'll start using actual 90w gear oil.
Thu Jun 26, 2014 6:47 pm
Just checked no oil leaking
Thu Jun 26, 2014 6:48 pm
Either way, what you are experiencing is normal, nothing to worry about.
Thu Jun 26, 2014 6:51 pm
Thu Jun 26, 2014 6:55 pm
Thanks I appreciate the settling help
Thu Jun 26, 2014 7:20 pm
1754 GTB / 35 GTR
Thu Jun 26, 2014 8:41 pm
x2
1852 Dfou custom 35gtr
Thu Jun 26, 2014 8:48 pm
I have never ran across one that doesn't spin in neutral. NEVER EVER and EVER !!
Don't care what DDM or anyone else says about theirs not spinning. I just know that its the norm for what I've seen ( which is in the hundreds ). And Truthfully with a tie rap and the reverse lever I can post a video of one not turning too! LOL
PD doesn't spin because it has a break built into the clutch when disengaged.
It spins because it still has the friction of the clutch bearings spinning on the PTO shaft. Which is a great thing if you think about it. It tells you your lower unit is free and not binding in the slightest. The Planetary gear is not in operation until you apply pressure to the rotor. Now once you get the planetary moving it then becomes weight in motion and acts like a flywheel.
Thu Jun 26, 2014 9:02 pm
my buddies has spun from day one
GatorHide - MB
Thu Jun 26, 2014 9:03 pm
Hmmmm.....
18x48 GDSD boat
Thu Jun 26, 2014 9:10 pm
Mine spun with 3 minutes on the tach and still spins. Not worried about it.
[color=#80BF00][b]Excel 1860 swv4f4 with GTR35L with stage 1, cam, exhaust, heads
Thu Jun 26, 2014 9:14 pm
Mine has always spun lil
Thu Jun 26, 2014 9:15 pm
it aint gonna kill nobody. it is what it is
GatorHide - MB
Thu Jun 26, 2014 9:19 pm
Thu Jun 26, 2014 9:20 pm
Mine has always spun in neutral but when I change the grease in the shaft log it spins much less.
Thu Jun 26, 2014 10:02 pm
Thu Jun 26, 2014 10:21 pm
in North Alabama I am the only person I know with a gtr and as I noticed it getting faster after I installed my motor back on the frame I wanted to know. I don't care if it spins but when it idles me around the boat ramp in neutral I get curious
Thu Jun 26, 2014 10:35 pm
Just apply a small amount of pressure on the reverse handle when you want to come to a complete idle in open water. Doesn't take much at all to get it to stop rotating.
Thu Jun 26, 2014 10:43 pm
Thu Jun 26, 2014 11:04 pm
Yeah I know that Bayou boy....
Thu Jun 26, 2014 11:27 pm
:lol: Yeah bitch he knows that...... :lol:
Fri Jun 27, 2014 3:31 am
Fri Jun 27, 2014 10:08 am
Fri Jun 27, 2014 10:10 am
I think it's funny when someone tries to tell me how to operate my boat when I can steer 35 barges down the Mississippi River. But thanks for the mechanical advice since that's what I originally asked for
Fri Jun 27, 2014 10:13 am
Has anyone really seen this bayouboy in person? He knows an awful lot about the inner workings of a Gator Tail? From Venice?? Just curious.
Fri Jun 27, 2014 10:17 am
Fri Jun 27, 2014 10:21 am
So does Gatortail actually have a real neutral? Yes or no?
UMRking do you ever work up around Cairo/Hickman area? I have been comm fishing there and I am super impressed with the driving on some of those bends. Lots of horsepower being used there.
18x48 GDSD boat
Fri Jun 27, 2014 10:38 am
Thanks Breaux
Yeah Ingram has a fleet in Columbus, KY we go down there to drop and pick up barges... I like coming through Cairo it's always interesting to see the Mississippi and Ohio meet
Fri Jun 27, 2014 10:48 am
I may have made it sound confusing with my post. But yes it has neutral engaged with a switch kind of like turning your lawn mower blades on and off. If that's what you were asking. Thru the planetary gear reverse system there is a little friction in there causing the propellar to spin slowly. Enough to barely make your boat move.. Fat baby crawl barely
Fri Jun 27, 2014 10:52 am
Users browsing this forum: No registered users and 187 guests
