It is currently Mon Jun 30, 2025 12:39 am
Reply to topic  [ 14 posts ]
 custom aluminum trailer company?
Post custom aluminum trailer company?
Anyone recommend one? I sold my old Diamond City (all aluminum) which I had custom built to my rig. What I liked was it was very light, strong, all wires were hidden, LED's, and pulled like a dream. The problem was the the original axle was built with camber which wore out the outsides of my tires. I did replace the axle which cured the problem. I have a top of the line McClain aluminum trailer constructed with all I-beam, and u-bolts, torsion axle, radials. It is just heavy. I do like the torsion axle vs the spring set up as this trailer is very smooth on the road. My objective would be to build one to my specs with all channel, hidden wires, and torsion axle. I know there are companies out there, but living up here in ND my options are limited. Thanks in advance for any suggestions and information you guys have.
Crisis defines character
Sun Jul 06, 2014 10:46 am
Post Re: custom aluminum trailer company?
I would rather have it with I beams not channel they flex way to much
Sent from my iPhone using
Sun Jul 06, 2014 10:57 am
Yea that's easy...no problem
Sent from my HTC One mini using Tapatalk
Sun Jul 06, 2014 11:58 am
Maybe try them, they are a sponsor here.
Sun Jul 06, 2014 1:12 pm
Definitely good looking trailers - anyone dealt with them?
I understand about the flex but if designed right with good support it won't be an issue.
Sun Jul 06, 2014 1:26 pm
I called him looking for a trailer…prices were very reasonable..but couldn't find anyone else that had used them, and he only had about 3 posts since becoming a sponsor (several months)….and being about 7 hrs away and with my work schedule….I wanted positive reviews before I sent my money into someone for a deposit, Especially all the run-around some members were having with a start up boat builder at the time …If I had lived closer he would have gotten my business for sure.
Bobcat Mag 1 Pirogue with paddle
Brother Breaux 16x36 with a 23 GDLT
Sun Jul 06, 2014 7:02 pm
http://www.coastlinetrailermfg.net/site/
I dont own one but they build a really good trailer.
Mon Jul 07, 2014 10:01 am
Call Back water they just started producing some
35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close
10hp Swomp lite 14-36 alumacraft
Mon Jul 07, 2014 11:16 am
Anyone else know of any good trailer dealers or custom trailer builders in the louisiana area? Boat will be 21' 66" with a small degree v. 150 fourstroke hanging off the rear. Contemplating between single and tandem axle.
Sun Jul 20, 2014 7:19 pm
You need a tandem.
Sun Jul 20, 2014 7:52 pm
Yep a tandem!!!!
Mon Jul 21, 2014 5:27 am
I hate tandem axles, by the time you realize you have a flat you've done ate the tire off the rim and maybe tore something up! I had a single 5000lb axle under my 20' with a 150 yamadog, Worked great!
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Jul 21, 2014 7:47 am
- Mark Twain
Mon Jul 21, 2014 9:49 am
west coast here in florida. Ill try to find the name of the place. Sold the boat and trailer
Mon Jul 21, 2014 11:25 am
Users browsing this forum: No registered users and 262 guests
