It is currently Sun Jun 29, 2025 2:36 am
Reply to topic  [ 15 posts ]
 Best flooring for a Jon boat?
Post Best flooring for a Jon boat?
What would be the best flooring for a jon boat? Also post up pics of flooring if you have them
Thanks
Stephen
Wed Aug 27, 2014 7:12 pm
Post Re: Best flooring for a Jon boat?
G3 project boat
Wed Aug 27, 2014 9:44 pm
Thu Aug 28, 2014 5:41 am
Then cover it with Best Step anti fatigue foam from Sears.
Thu Aug 28, 2014 5:47 am
Ive got 3 boats with 1/2" AC fur for flooring...its gonna be the easiest to work with if you wanted to go with wood...its the most water resistant wood you can get...Coat it with zintox and it will last as long as your boat...Ive 2 that are 7 years now no rot...Just another alternative if you wanted to use wood..
Thu Aug 28, 2014 6:48 am
4x4' scrap aluminum road construction signs or 4x8' Interstate exit signs, rivited or welded and fitted around ribs. Used 1 Qt. oil bottles silconed glue to bottom of boat between ribs for support and floatation. Prime and painted with roll on truck bed paint.
Thu Aug 28, 2014 12:56 pm
Aluminum and used closed cell foam sheet underneath it and pop riveted it.
Thu Aug 28, 2014 7:10 pm
I did a cheap alternative, 1/2 inch plywood with sealer on it. Works for me and was only $20 for a sheet. I put carpet over it, and run it!!
Been on for a year and a half, i leave the boat outside 24 /7 and its still strong as day 1
Wed Sep 03, 2014 8:58 am
I used marine grade plywood covered with camo neo mating. Works good for me.
Running a Alumacraft 1442 NCS with a 25 HP Orion surface drive. Not the best, but it works.
Wed Sep 03, 2014 3:52 pm
Did marine grade plywood with truck bed liner for traction and paint
Wed Sep 03, 2014 6:34 pm
I was going to use marine grade plywood but that stuff cost more then a 4 by 10 sheet of 1/10" aluminum and aluminum is way lighter and will never ever break down.
Wed Sep 03, 2014 8:22 pm
For my 24x72 Seaark I used 3/16 tread plate aluminum. My boat was/is beat up from commercial fishing and the sides are dinged up and the ribs were broken in the center of the boat. I went with the thicker floor to stiffen the boat up. I found the ribs are not on center and as mentioned I made a jig for one side and a jig for the other. Worked out good. The floor is now sealed and she rams waves with the best of them. She is my second comm fishing boat and sees action every now and then. The big plate boat gets the daily call and it has 1/8 treadplate flooring. However the ribs are 12 inch centers. Go aluminum.
18x48 GDSD boat
Wed Sep 03, 2014 9:52 pm
Fri Sep 05, 2014 1:27 pm
Depends what you call a jon boat... Is this a 14' pop rivet hull or a custom welded 18 footer? On my 14' I took closed cell foam and cut to fit between the ribs of the floor to level it out and then topped it with Neo-mats to hold down the foam and give some extra squish... It's all removable to wash out twice a year and stays put while trailered and going down the highway or interstate. How much is this boat worth? Couple hundred bucks you'd bet Id be happy with some sealed plywood cut to fit... But if you dropped the money on a nice custom hull, go all the way and do it right so it'll last.
1436 Lowe
Fri Sep 05, 2014 3:27 pm
For less then a couple hundred bucks you can get a sheet of 1/10" aluminum 4 by 10 foot.
Sat Sep 06, 2014 12:25 pm
Users browsing this forum: No registered users and 208 guests
