It is currently Sun Jun 29, 2025 7:35 am
Reply to topic  [ 11 posts ]
 Charge your battery?
Post Charge your battery?
So my battery is about a year old and it wasn't acting sluggish when I went out, but I got down river about 3 miles from my launch and cut the engine. When I went to start it again, the battery was dead. I was thinking the alternator was charging my battery, but maybe not. Any thoughts?
I recharged the battery and had it load tested and they said it was good.
GTB 1646 w/HD, Boat Blind-25GTR
SOUTHEAST GATORTAIL
Sun Sep 07, 2014 9:20 am
Post Re: Charge your battery?
put a meter on your battery and see what its at when motor is at idle and when motor is about 2000 rpms not sure what charging system the 25 has
07 16x50 w/ 07 35 gtr
Sun Sep 07, 2014 10:01 am
Do you have any extra lights or winch or any accesories that could be pulling from it will its not running?
Excel 1851vF86 w/ MB 55V
SHIT HAPPENS
Sun Sep 07, 2014 11:34 am
Get yourself an Optima Blue and thank me later!
Sun Sep 07, 2014 11:55 am
Yea I have 4 18W LEDs on the front, but there were not on, bow and stern lights as well, gps...My GPS was on when it died, but didn't think it was the issue. I check all my switches and none were on. I have an on board battery charger that I will just hook up and charge the battery. A buddy brought me a new battery out to the river when I was in a bind.
SOUTHEAST GATORTAIL
Sun Sep 07, 2014 1:35 pm
Bullet 21 CC w/ 225 PM
PD 1856 w/ 36PD
Legend V-21 with Mercury 250 XS
20' G3 Pontoon with 90 yamaha
Sun Sep 07, 2014 3:48 pm
Yea. Alternator is not charging or you have some wiring issues causing assecories to draw when not in use.
SHIT HAPPENS
Sun Sep 07, 2014 5:20 pm
If it cranked fine at the ramp and was then dead after you shut it off, I'll bet you accidentally left the key in the 'on' position and the ECU killed your battery. How long between shutting it off and trying to restart?
Since doing it once (at the house, luckily), when I set up to hunt, part of my routine is removing the key from the ignition altogether and stowing it in my boat bag.
There's a thread here in the engine forum titled "adding a pull start" in which a pretty slick little backup battery is discussed in case of a main battery failure. A bunch of us have bought these little batteries or similar ones; might want to check them out.
http://store.starkpower.com/Jump-Box-Ba ... _c_37.html
Not much bigger than a cell phone and they offer between 200-300cca and 400-600 peak cranking amps for $100-120 and weigh about 1-2lbs.
Sun Sep 07, 2014 10:10 pm
Mon Sep 08, 2014 11:03 am
This is what I carry with me...it will jump a boat/truck and will charge a phone. Comes with a bunch of different adaptors to fit anything that needs to be charged
1756 Phowler 36PD
Mon Sep 08, 2014 6:19 pm
Something similar happened to me, cranked up at the launch fine and when we went to leave the first fishing hole I had a dead battery. I called gator tail and Hoyt told me to cut the plug that snaps the wires together coming from the voltage regulator and splice it back without the snap plug, he said that's usually the first thing to go. It was already done by the previous owner so I had to by a new voltage regulator which was $93 and now I'm good to go. Just something you can look into.
Tue Sep 09, 2014 6:51 am
Users browsing this forum: No registered users and 261 guests
