It is currently Thu Jun 26, 2025 5:40 pm
Reply to topic  [ 11 posts ]
 Need suggestion on a motor for my 1548 semi v weld-craft
Post Need suggestion on a motor for my 1548 semi v weld-craft
I have been looking at the MB, GTR, PD but told to stay away from Dixies, looking for your guys oppinion. Along with brand what HP would you put on the 1548 semi v weld craft, want to go as big as possible(go bid or go home right). Don't want to wish later on I want bigger. Also thinking about pod heard good and bad things so want to get more thoughts. Any help and info will be greatly appreciate thanks guy.
Wed May 04, 2016 10:03 pm
Post Re: Need suggestion on a motor for my 1548 semi v weld-craft
pointless putting a mud motor on a semi V, if you do put a mud motor on that hull build up your transom. The 25's do not weigh that much less then the 35/37's . All the brands other then Dixie have their pros and cons.
Fri May 06, 2016 1:06 pm
My dixie been doing great had it for over a year, the only problem i have is the relay for the trim gets wet easily, i keep a spare with me just incase. Still don't recommend getting one tho lol
Fri May 06, 2016 1:15 pm
Fri May 06, 2016 1:22 pm
Get you a 100 hp For Sale Sign and get you another boat.
And if you must keep the boat, and you add pods to it, then save your money on the for sale sign and just cut it up for scrap.
Look around the forum, search it on google.
You have find more information than you know what to do with.
Fri May 06, 2016 4:47 pm
I had a Modified V 1548 Weldbilt. Ran a 20hp Longtail on it and it did fine. Not the best in straight mud but it would get you there. Not the best out there but hey, I was hunting, that's all I cared. If you run it hard, you will get a couple seasons out of it tops. But it'll get you by long enough to figure out what mud rig you really want. I ran 20mph unloaded and solo, 15-16 with two and gear.
-Custom pool noodle
-stage 4 water wings
Fri May 06, 2016 7:25 pm
Fri May 06, 2016 7:41 pm
Not everybody hunts on a mud flat........... so..... Yeah, it worked fine for me for several years. Not to mention, we're not talking about an offshore boat type V like people make out. The center of the boat was maybe 4" deeper than the chine. To flat out just say that it won't work is ridiculous. They're serviceable. They get the job done, but there are better options out there..... If you already have the hull and don't want to swap or can't for any number of reasons then it will get you there. A flat hull just makes what we do more efficient and easier to accomplish for the most part.
-Custom pool noodle
Fri May 06, 2016 8:42 pm
Fri May 06, 2016 9:01 pm
Don't play around, I'll go full novel on your ass :lol:
-Custom pool noodle
Fri May 06, 2016 9:19 pm
Fri May 06, 2016 9:23 pm
Users browsing this forum: Google [Bot] and 276 guests
