It is currently Sat Sep 20, 2025 8:07 pm
Reply to topic  [ 17 posts ]
 PD wont start after 6 hr drive up north
Post PD wont start after 6 hr drive up north
After a 6 hr drive on the trailer it wont start. Gives one short rev and quits. Plug was fouled and after a few key turns, remove both plugs, gas was dripping out one of the cylinders.
Other than clean the plugs up and waiting till its no longer flooded, any other suggestions to get on the water?
Thanks
Sent from my SM-G930R4 using Tapatalk
Sun Aug 12, 2018 2:40 pm
Post Re: PD wont start after 6 hr drive up north
Any possibility that your tank was not vented that whole trip?
With the gas moving around, could cause pressure in an unvented tank, causing the fuel to push through the carb.
just a thought..
Refurbishing a Prodrive
Sun Aug 12, 2018 4:46 pm
^ What he said.
Sun Aug 12, 2018 7:01 pm
Nope it is always vented. The tab was removed after buying it. I removed the plugs, cleaned, let it sit and a couple of quick key turns with no plugs. After an hour it started right up.
Let the vacation begin. ;)
Tue Aug 14, 2018 6:35 am
sometimes when I haul azz down the levee and it's real rough, I have to pull my plugs and spin the motor over and blow gas out the cylinders before I can start the motor. then it runs fine all day.
it did this like 2 years ago. I changed the carb and it never did it again.
Tue Aug 14, 2018 6:59 pm
Seen some funky issues before that was unexplainable... changes the float needle and things got better. Used carbs for these things are a dime a dozen...
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Aug 15, 2018 5:34 am
This was on the trailer. Next time may want to disconnect the gas line and figure out a way to cap the disconnected line.
Thanks All
Mon Aug 20, 2018 10:17 am
Dang, you're in Wisconsin and you drove 6 hours north?
I'd be curious if you unplug the gas line on the way back south, and it does, or doesn't, do the same thing.
GoDevil 18X44
GoDevil 35 SD
Mon Aug 20, 2018 12:13 pm
Mon Aug 20, 2018 2:46 pm
Could you install a inline on/off valve? Or is it more of the gas still in the engine causing the issue?
Mon Aug 20, 2018 4:57 pm
Tue Aug 21, 2018 7:26 am
It's the pressure in the tank from all the sloshing around and heat forcing gas through the line into the engine.
#TheGhostBoat
Tue Aug 21, 2018 8:17 am
Tue Aug 21, 2018 12:57 pm
There was supposed to be a t and apostrophe in there. Wasnt asking, was clarifying. Edited now.
#TheGhostBoat
Tue Aug 21, 2018 4:26 pm
Wed Aug 22, 2018 9:49 am
Just disconnect the line or leave the cap cracked so pressure doesnt build.
#TheGhostBoat
Wed Aug 22, 2018 10:08 am
Bayou Surface Drive
337-351-0362
Wed Aug 22, 2018 12:31 pm
