It is currently Fri Feb 13, 2026 7:47 am
Reply to topic  [ 4 posts ]
 Oil/Grease below clutch???
Post Oil/Grease below clutch???
I am getting a bunch of oil or grease build up below the clutch. Is this something to be worried with or is it normal? I thougth maybe I put too much grease in the grease jerks but this is kind of a milky color. I do have a case gasket leak that hasn't been fixed, but I don't think it is related to this as I am not loosing that much oil.
Suggestions?
WC Custom 1854
Sun Mar 08, 2009 6:22 pm
Post Re: Oil/Grease below clutch???
Water is getting in lower unit!Mine did the same thing,Change the seals!
Sun Mar 08, 2009 8:31 pm
Gear lube from the lower unit. Grease will not change color and mix with water like that. Probably need a new upper seal.
18x48 Charles Leonard / 36PD
Sun Mar 08, 2009 8:45 pm
What's involved with changing the seals???? Is it an easy job? The engine only has 60 hours on it. How much will the seals run?
WC Custom 1854
Mon Mar 09, 2009 5:52 am
