It is currently Sat Jun 28, 2025 4:18 am
Reply to topic  [ 10 posts ]
 35gd sd rev limiter wiring
Post 35gd sd rev limiter wiring
having a problem with the colors of the wires there just not there !!!
got the black-ground to starter
there is a green in my cluster but... its cut at the plug and doesnt go to anything after it comes out of it.
see what yall can come up with and let me know
much thanks kenneth
Tue Aug 03, 2010 8:06 pm
Profile YIM
Post Re: 35gd sd rev limiter wiring
bump
Tue Aug 03, 2010 8:42 pm
Profile YIM
White is positive.
Black is negative.
Green is ground.
Tue Aug 03, 2010 8:50 pm
Tue Aug 03, 2010 9:11 pm
Profile YIM
then the red is more than likely the positive.
Tue Aug 03, 2010 9:22 pm
Tue Aug 03, 2010 9:30 pm
Profile YIM
On MBs the green at the large plug connector is pigtailed to the black in the harness where the kill switch, key switch, and oil pressure sensor (if installed) connect in a circuit to the ground wires for the coils. If any of these things ground it keeps the coils from firing. The green on the rev limiter is more of a control wire and when the rev limiter trips, it grounds that wire to kill the spark.
One suggestion I would make is to add a connector on the green wire near the rev limiter. If you ever suspect the limiter has failed and the motor will not start, you can quickly disconect the green wire and remove the rev limiter as a variable.
Wed Aug 04, 2010 4:46 am
Wed Aug 04, 2010 4:54 am
Profile YIM
Wed Aug 04, 2010 7:03 am
Ok thanks man
Wed Aug 04, 2010 9:30 am
Profile YIM
Users browsing this forum: Google [Bot] and 97 guests
