It is currently Sat Jun 28, 2025 12:55 pm
[ 7 posts ] |
Quack Smacker
 possible air lock
had motor running last night and ran outta fuel. now today refilled tank and couldnt get her to fire. i can see no fuel entering filter on fuel line. of course i have no primer bulb on my line any suggestions guys
Sat Aug 07, 2010 9:19 pm |
deadbird8
 Re: possible air lock
Close the vent on the tank and stand on it or blow into the tank to pressurize the line. You can take off the air filter and drop a little fuel in the carb intake to just get it started (or use starting fluid).
I don't run with a primer bulb either and my old motor had a hard time when I ran it out of gas (same as you describe), my CDI with the different pump setup doesn't seem to have a problem at all. I guess its different on every motor.
Sun Aug 08, 2010 5:08 am |
Quack Smacker
tried that man got fuel ti the filter one time but couldnt get it back think my fuel pump might be out. i get the motor runnin with starting fluid but only momentary because lack of fuel.
Sun Aug 08, 2010 5:42 am |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
Pick you up a primer bulb and pump it up tight, and get the motor running with carb cleaner while you pump the sht out of the bulb. If you get the fuel lines all tight and it still won't run, you probably lost yer fuel pump. I run an electric fuel pump from Napa because my motor's pump wouldn't pull gas from the front of the boat.
_________________ Put yer face in the myrtles.
Sun Aug 08, 2010 6:13 am |
Quack Smacker
appreciate it guys
Sun Aug 08, 2010 6:41 am |
saveontaxes
_________________ Gator Trax 1854 ran over by drunk driver!! ( boat less)
Sun Aug 08, 2010 8:20 am |
deadbird8
If all else fails, there is the e-fuel pump cure!
Thu Aug 12, 2010 5:04 pm |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 178 guests |
