It is currently Mon Jun 30, 2025 2:06 am
Reply to topic  [ 8 posts ]
 16 hp B&S Vanguard on GO DEVIL
Post 16 hp B&S Vanguard on GO DEVIL
Could use some help. When idling or full speed the fuel filter empties and the engine sputters and then dies. Replaced priming bulb, fuel filter, 1/4 inch fuel line, fuel pump, and tank fittings. That didn't fix the problem. Took fitting off of hose and stuck hose in a gas can of fresh fuel to eliminate possible fitting or tank issue. Nothing seems to fix the problem. It doesn't seem to even be pumping fuel. HEEEELLLP!!!
Thanks in advance.
Tue Oct 12, 2010 7:52 pm
Post Re: 16 hp B&S Vanguard on GO DEVIL
might sound elementary, but it really sounds like air leaking in from a fiiting
Tue Oct 12, 2010 7:55 pm
Checked and rechecked all clamps. Tried with a fuel filter and a piece of hose. Wondering if maybe an issue with carb. Added the priming bulb back and pumped it up. Can't find any possible air leaks. It won't pump any fuel at all. Could the port on the valve cover where the short hose to fuel pump connect be a possibility?
Tue Oct 12, 2010 8:14 pm
that or is the hose to long i had a problem with mine not wanting to draw up the fuel
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Tue Oct 12, 2010 8:15 pm
it could def be the hose, disconnect hose from carb, pull your kill swich lanyard, and try to start it, fuel should pump out
Tue Oct 12, 2010 8:17 pm
I only have 6 feet total fuel hose. I will try disconnecting line from carb tomorrow. Thanks I appreciate the help.
Tue Oct 12, 2010 8:38 pm
fuel pump mine did the same thing
Wed Oct 13, 2010 7:42 pm
New fuel line, new priming bulb, new fuel pump, new fuel tank, fresh fuel, new fitting where hose attaches to tank, and fitting on tank. Retightened hose clamps. Took hose loose from carb, pulled kill switch, turned key, and watched it pump fuel. Think maybe an issue with the carb. Fuel filter still loses prime. Can watch the fuel drain out.
Thu Oct 14, 2010 7:01 pm
Users browsing this forum: No registered users and 76 guests
