It is currently Sat Jul 05, 2025 8:52 am
Reply to topic  [ 10 posts ]
 Oil coming out of vavle cover vent tube
Post Oil coming out of vavle cover vent tube
This my first post I think but I have a prob. I bought a BPS Mukuni single kit and it didn't come with any kind of adapter for the valve cover vent. My prob is that it is now leaking oil from the vent tube not like alittle oil but enough to make me worry. I talked to a guy at BPS and he said it sounded like a head gasket but I just find it hard to beleive cause it was fine before when it was running striaght to the stock intake. Any input or questions will be greatly appericated. Boat runs fine 4300-4400 rpms the other day but just leaking oil.
Tue Jul 05, 2011 5:15 pm
Post Re: Oil coming out of vavle cover vent tube
i would do a leak down test on your engine. pin point your problem than fix it.
JUST ANOTHER FARMER ON WELFARE
Tue Jul 05, 2011 5:40 pm
They will do that when it is hot and the motor is working hard. Especially at those rpms.
Tue Jul 05, 2011 6:23 pm
I have the same problem
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Tue Jul 05, 2011 7:00 pm
yes hot conditions will effect blow by. but if you have oil running out of breather tube like u said i think u need to do a leak down it will tell if u have bad rings bad gasket set and other conditions. your blow by might have always been there. with the old carb u were pulling the blow by back into the engine through the air cleaner plate. a over filled oil condition can also cause high blow by conditions and cause excessive vac. readings.
Tue Jul 05, 2011 8:12 pm
Blown head gasket, or leaking valve stem seals are what I have found to be the most common causes of this. However as others have pointed out, on exceptionally hot days very slight seepages will come out of that tube.
Wed Jul 06, 2011 9:09 am
Wed Jul 06, 2011 9:42 am
Well I did the leak down test and the vent side head had air coming through the bottom of the head guessing the oil drain holes it also has only 80 psi of compression. The fill caps side is fine no leaks or any thing it has 120psi of compression. So head gasket or rings I guess?
Wed Jul 06, 2011 12:47 pm
If you did a true leak down test what was the percentage of leakage on the gauge?
BUCK OFAMA
Sat Jul 09, 2011 10:25 pm
Mon Jul 11, 2011 8:58 am
Users browsing this forum: No registered users and 138 guests
