It is currently Thu Jul 17, 2025 5:56 pm
Reply to topic  [ 35 posts ]
 36pd dies?
Post 36pd dies?
Hey guys I have a stage 1 36pd.. I was out working on duck blinds last weekend and as I was coming back in to the boat ramp I was running wo in deep water and it just dropped rpms and died.. It started right back up and I continued back to the ramp.. It doesn't do it all the time just once in awhile.. Just wondering if any of you have had this problem.. And suggestions would help. Thanks
Tue Oct 02, 2012 5:12 am
Post Re: 36pd dies?
Saltwater on plug wires. Wrap em with electrical tape.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 5:55 am
Post Re: 36pd dies?
Or sounds like maybe you lost fuel pressure? Is it a CDI motor?
Tue Oct 02, 2012 6:55 am
Post Re: 36pd dies?
Sounds like a fuel issue like OD said. Check all your fittings for air leaks.
Tue Oct 02, 2012 7:30 am
Post Re: 36pd dies?
No salt water around here.. An it is a cdi motor.. And I put an epump on it and checked all the clamps/fittings/etc multiple times so I don't believe it is fuel
Tue Oct 02, 2012 7:33 am
Post Re: 36pd dies?
How many times did you use it after you put the pump on?
Tue Oct 02, 2012 7:39 am
Post Re: 36pd dies?
3 times running up the river to cut willows.. About 3 mile ride one way.. Didn't do it then
Tue Oct 02, 2012 7:50 am
Post Re: 36pd dies?
Not sure man, I don't have an e pump but unless someone else has an idea, I still think it is a fuel starving issue...
It runs fine when it runs, right?
Tue Oct 02, 2012 8:08 am
Post Re: 36pd dies?
Gas tank vent is closed?
35 GTR - 1754 Extreme
Tue Oct 02, 2012 8:10 am
Post Re: 36pd dies?
There's CJB's distracting ass avatar again LOL
What was the topic???
Tue Oct 02, 2012 8:13 am
Post Re: 36pd dies?
Yea when it runs it runs good!!... The only other thing is when it was bogging I did hear a bit of knocking but it doesn't do that when its running good
Tue Oct 02, 2012 9:17 am
Post Re: 36pd dies?
Do you have a water separating fuel filter? I had similar trouble once because my fuel filter was "clogged" with water. The filters are designed to let smaller fuel molecules pass, but stop the larger water particles. If you get enough water in there (thanks ethanol) you can essentially clog the filter and not enough fuel can pass through to the carb.
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Tue Oct 02, 2012 9:44 am
Post Re: 36pd dies?
I will have to pick one up n try that
Tue Oct 02, 2012 9:54 am
Post Re: 36pd dies?
Do you have a rev limiter installed?
Tue Oct 02, 2012 10:40 am
Post Re: 36pd dies?
Yea I do have a rev limiter on it
Tue Oct 02, 2012 11:00 am
Post Re: 36pd dies?
Mine has done the same thing a few times. Last season it happened almost every time I cranked up and started running. I'd get on WOT, it would get to about 4k RPMs and just die like it was starving for gas. Would crank right back up and be fine the rest of the trip. Thought I was hitting the rev limiter, but it wouldn't bounce it would just die.. Redid all my fuel lines, connections, filter, and fuel primer bulb couple weeks ago. Found a small crack in the primer bulb when I pulled it out. Everything has been good through the last couple of weeks hunting, until it did it again 1 more time the other day... died around 4k RPMs cranked right back up and was ok for the rest of the 20 minute run. So I don't know.
1848 Sportsman Fab
36 PD
Tue Oct 02, 2012 12:30 pm
Post Re: 36pd dies?
Bug's was doing the exact same thing, it turned out to be the quick connects on the gas tank.
Tue Oct 02, 2012 12:43 pm
Post Re: 36pd dies?
Tue Oct 02, 2012 12:47 pm
Post Re: 36pd dies?
I had the same problem and it was a faulty circuit breaker between the rev limiter and the wiring harness.
The breaker would trip and my engine would sputter and die. I had the type of breaker that auto reset and it had to be 8+ years old. Replaced the breaker and it hasn't acted up again.
Tue Oct 02, 2012 12:53 pm
Post Re: 36pd dies?
Also, i would loose my trim power when the circuit breaker flipped.
The engine would turn over, but not start (just like it does if you pull your kill switch). I would know when the breaker auto reset because the trim would start working again and then the motor would start up first turn of the key.
Tue Oct 02, 2012 12:56 pm
Post Re: 36pd dies?
I thought it was a fuel problem when it first happened.. So I replaced the hose/clamps also got rid of the quick connect on my tank and went to a direct pickup out of the tank.. Still did it so I put an epump on it seemed to solve it until it did it Saturday.. I'm stumped
Tue Oct 02, 2012 2:07 pm
Post Re: 36pd dies?
Disconnect the rev limiter.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 2:20 pm
Post Re: 36pd dies?
Camo,
If it happens again, how should i disconnect the rev limiter?
Do i need to do anything other than cut the wires going to and from it?
I am asking from an "in the field" perspective
Tue Oct 02, 2012 2:29 pm
Post Re: 36pd dies?
Honestly, if you have a cdi motor, you don't need the aftermarket rev limiter. The coils have a built in 4300 rpm rev limit.
But to answer your question, yes, just cut or unplug the green wire.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 2:46 pm
Post Re: 36pd dies?
He may be talking about the factory limiter, rob.
Tue Oct 02, 2012 2:50 pm
Post Re: 36pd dies?
:-? ...then you....um...can't... :lol:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 3:02 pm
Post Re: 36pd dies?
Can you idle and cruise around at low rpm with no issues? Only happens during a stretch of WOT?
Tue Oct 02, 2012 3:06 pm
Post Re: 36pd dies?
Yea it only happen wfo
Tue Oct 02, 2012 3:22 pm
Post Re: 36pd dies?
Were you talking about the built in cdi rev limiter, or do you have Mikuni & rev box??
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 3:30 pm
Post Re: 36pd dies?
Built in cdi
Tue Oct 02, 2012 3:33 pm
Post Re: 36pd dies?
Wed Oct 03, 2012 8:02 am
Post Re: 36pd dies?
Fri Oct 05, 2012 5:36 am
Post Re: 36pd dies?
I love when DB comes around
Fri Oct 05, 2012 5:47 am
Post Re: 36pd dies?
Fri Oct 05, 2012 7:26 am
Post Re: 36pd dies?
Something else to check is the primer bulbs have a small check valve in them, if it colapses then the motor will starve for fuel, easy inexpensive repair. It shut me down on a hunt, the only way for me to stay running was pump the bulb constantly.
Thats before i had my electric fuel pump though but if your fuel pump doesn't stay on then i can see it happening.
Fri Oct 05, 2012 10:06 am
Users browsing this forum: No registered users and 129 guests
