It is currently Mon Apr 13, 2026 1:48 am
Reply to topic  [ 4 posts ]
 PD Engine Bolts
Post PD Engine Bolts
On the front of my PD where the motor fits over the transom the 2 square headed bolts were fairly loose after using the boat this weekend....PD manual states to torque the bolts to 25lbs, who critical Is the using of a torque wrench to get it to exactly 25lbs vs tightening fairly snug with a socket??? What could have caused the bolts to come loose in the first place?
Mon Oct 05, 2015 4:28 pm
Post Re: PD Engine Bolts
I just normally tighten down a good bit. I never used a torque wrench.
It's happened to me before. Easy fix was using red locktight on the bolts. Never had that problem again.
Refurbishing a Prodrive
Mon Oct 05, 2015 5:15 pm
Those will loosen up on you. I know both of mine are torqued WAY more than 25 ft-lbs! LOL
Most liberals seem to suffer from the same mental condition....it's called stupidity!
Mon Oct 05, 2015 7:16 pm
That's what I did, took a socket and just put a good tighten on it.
Tue Oct 06, 2015 9:15 am
