richard nagon
 Sump cover
Seen some new efi with gaskets and some with sealer only. On the cover that is. Any one else seen this ?.
_________________ JUST ANOTHER FARMER ON WELFARE
| Fri Dec 04, 2015 12:55 pm |
MaXXis85
 Re: Sump cover
| Fri Dec 04, 2015 1:05 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: Sump cover
FYI, if you ever R&R a cover that came with sealant only, go to your Ford dealer and ask for a 7.3L oil pan gasket. They'll hand you a tube of grey (silicone) magic. Take said magic home and apply it to your motor  if you ever need to take it off again, have hammer and chisel on standby. Won't leak though.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Fri Dec 04, 2015 3:26 pm |
deadbird8
 Re: Sump cover
Newest motors are coming with sealant only. I have used Yamabond 4 on them.
| Sat Dec 05, 2015 1:57 pm |
gaducker
 Re: Sump cover
Yama bond holding up? I have taken an oil pan off a power stroke and I don't know if I want to quiet that strong in the bonding dept. although that maybe what it takes.
_________________ 1864 4man hide minus the hide, 5500 mudbuddy, 32 inches, my version of a hammer, Wolfmans muffler with underwater silencer.
| Wed Dec 09, 2015 5:27 pm |
SETx Longtail
 Re: Sump cover
Like I said, hammer and chisel
| Wed Dec 09, 2015 10:09 pm |
deadbird8
 Re: Sump cover
The Yamabond has held to date. I took one apart recently that was sealed with Yamabond and had to really lever on the 3 tabs on the case to get it to let go.
I did check out the Motorcraft TA-31 used on the 7.3L diesels- I like that it comes in a tube you can apply with a caulk gun.
| Fri Dec 11, 2015 6:19 am |
MaXXis85
 Re: Sump cover
| Fri Dec 11, 2015 6:23 am |
deadbird8
 Re: Sump cover
I just did a case gasket this morning with the Motorcraft TA-31- that stuff is the stickiest RTV I have ever come across. I expect it will seal well.
Have the majority of the tube left over, not sure how well it will keep though.
| Fri Dec 11, 2015 10:47 am |
SETx Longtail
 Re: Sump cover
| Fri Dec 11, 2015 10:51 am |
deadbird8
 Re: Sump cover
| Fri Dec 11, 2015 10:55 am |
SETx Longtail
 Re: Sump cover
Like you've got it, it'll last a long time. Several months I'd say. I always just leave a little hanging out the end and hang the gun up. Then pull the tab off the end when you need to use it again. I normally go thru a tube every month or so doing various things.
| Fri Dec 11, 2015 11:04 am |
hotdognjo
Joined: Mon Jan 26, 2009 10:04 am Posts: 480 Location: Laplace, LA
 Re: Sump cover
SETx, You think that sealant will fix a hairline crack in a PD sump? I have 2 that have cracked in the same place on a 2007. Thanks,
_________________ 1754 PD Center Console, 60 Yammy, w jack plate
| Sun Jan 31, 2016 2:32 pm |
SETx Longtail
 Re: Sump cover
Replied to your PM but in short, yes, I think it will work as a temp fix.
| Sun Jan 31, 2016 3:20 pm |
deadbird8
 Re: Sump cover
| Mon Feb 01, 2016 3:24 am |
deadbird8
 Re: Sump cover
| Mon Feb 01, 2016 7:06 am |
MaXXis85
 Re: Sump cover
| Mon Feb 01, 2016 9:39 am |
MaXXis85
 Re: Sump cover
I just seen this link on Permatex's site. Its called MOTO1. it is specifically designed for case halves. It is probably similar to Yamabond. http://www.permatex.com/products-2/prod ... rey-detail
| Mon Feb 01, 2016 10:05 am |
tyler_johnson
Joined: Mon Jan 21, 2013 6:22 pm Posts: 1094 Location: El Dorado-ish, AR
 Re: Sump cover
That is what I am using this time along with a gasket, even though ultra grey has worked well. I screwed the pooch and didn't pay attention to my bolts. Motor is apart in the shop now.
_________________ '13 GTR35 Stage 2 w/ EVT Exhaust, 1750 Voodoo Custom by DFOU!!
| Mon Feb 01, 2016 10:14 am |
Russ
 Re: Sump cover
I'm using the permatex anaerobic sealant along with the gasket. Seems OK to me so far. I've had to break the case twice since I started using this method, both times it looked OK when I pulled it apart. Just as long as you check and maintain appropriate torque on the bolts, there are at least 3 or 4 ways to skin this cat.
| Mon Feb 01, 2016 11:29 am |
MaXXis85
 Re: Sump cover
| Tue Feb 02, 2016 7:48 am |
